586,000 active members*
4,834 visitors online*
    Jul 2016
    Charmilles robofil 4020.0 lost reference
    If the power goes out, during the restart I get E070 execution inactive then E684 impossible operation. Which means I have lost my reference. My U axis is off by
    aprox. .750, So I do a guide setup and life is good till the next time. Some times the machine will shut down, startup , shut down and start up when either the generator
    or the pumps kick in with the same end result. I have replaced the K1 relay and went through all of the YV valves.
    Any suggestions would be appreciated.
    Jan 2006
    104
    Re: Charmilles robofil 4020.0 lost reference
    check your NC rack voltages. set 5 volts to 5.1 vdc measured at the backplane!!!!!!
    check and replace your batteries on the UA+SAL board.
    check your 24 vdc supply.
    thats a start
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Jul 2016
    I checked the voltage on the SAL Restart board
    5 v check 4.93
    -12 checked 12.09
    +12 checked 11.82
    The battery checks 4.11 volts.
    Oct 2016
    106
    Hi. Do you still own this machine?
    Sent from my D5803 using Tapatalk
  1. charmilles robofil 290
    By zekry10 in forum EDM Discussion General Topics
    Last Post: 02-24-2016, 02:25 AM
  2. DNC CHARMILLES ROBOFIL 310
    By tecnomaqq in forum EDM Discussion General Topics
    Last Post: 01-17-2014, 04:34 AM
  3. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  4. Charmilles Robofil 300 question
    By rtuls35 in forum EDM Discussion General Topics
    Last Post: 06-15-2011, 06:09 PM
