585,927 active members*
3,635 visitors online*
    Jul 2016
    19
    MSD data lost Emco Pc mill 125
    Is there any one who knows how to get te msd data from the Pc hard drive to the machine. Emco Pc mill 125 sinumerik 840.
    /B
    Re: MSD data lost Emco Pc mill 125
    PC Mill 125 is run by the PC. Did you find WinNC and WinConfig on the PC? WinNC is the control interface. Winconfig accesses the ini and MSD, but there should be nothing to change if the machine was running at some point, unless you have to reinstall.
    Jul 2016
    19
    Thanks for your reply! I am now able to run zero return on the machine.
    /B
  1. Emco 340 lost parameter maybe.
    By CASTLEVILLE in forum EMCO Lathe
    Last Post: 01-10-2013, 11:50 PM
  2. Need Machine Data 5002 on Emco 320
    By J_Copeland in forum EMCO Lathe
    Last Post: 08-22-2012, 05:29 PM
  3. EMCO 320 w/Fanuc Lost parameters!
    By erichegi in forum EMCO Lathe
    Last Post: 07-07-2011, 04:04 PM
  4. rover 336 data lost
    By freezengate in forum CNC Machining Centers
    Last Post: 11-17-2010, 10:07 PM
