Dear plasma users,
would you be so kind to give some hints on how to use M3/M5 G-code commands or modify the macro to use with Proma SD thc plasma controller?
A floating head to detect the material is used with a switcher (MACH3 program for the detection of material – is configured the switch as the PROBE input signal.)
How do you do it, what g-code/macro have you used? Did you test it with Proma SD torch height controller?
Please give some G-code examples of how you cut with plasma using Proma SD and info about setup!
Thank you,
Stan
