585,752 active members*
4,080 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > After running AI APC for 1st time, cannot exceed 3.75 IPM on arc moves
    Jan 2014
    5
    Hello, I am running a Bridgeport GX 480 with a Fanuc Oi-MC controller.
    I tried to use AI APC by using G5.1 Q1 R5 and now the machine won't exceed 3.75 inches per minute on a G02 or G03 move, even when AI APC is turned off. This is causing some issues for getting things done on time :tired:
    There were no issues with the machine before this, so i'm thinking that it may have overwritten a parameter with the wrong number??
    At this point, I'm not even worried about getting AI APC working, I'd settle for getting the machine back into efficient operation.
    I really appreciate any help I get on here, and thank you in advance!
    -Greg
    Jan 2014
    5
    Re: After running AI APC for 1st time, cannot exceed 3.75 IPM on arc moves
    fixed it! parameter 1730 was set to 0
  1. total on time and toal running time in fanuc?
    By maan_sunny in forum Machinery Manuals / Brochures
    Last Post: 01-25-2016, 06:48 AM
  2. QT150 alarm 272 turret index exceed time
    By vinch9292 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-23-2012, 03:43 AM
  3. PicStep Moves While Router Running Problem SORTED
    By dalescnc in forum CNC Machine Related Electronics
    Last Post: 09-16-2011, 12:54 AM
  4. X-axis moves position while running
    By will@djg in forum DNC Problems and Solutions
    Last Post: 10-13-2008, 06:40 AM
  5. Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn
    By jmullett in forum Dolphin CAD/CAM
    Last Post: 02-07-2007, 11:32 AM
