585,768 active members*
4,007 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > HELP NEEDED - Facing off gone bad!!!
    Nov 2014
    Any ideas what whould cause the finish shown in the attached picture.
    It has started happening with every piece we cut. We use our lathe for refinishing alloy wheels and this is the finish we get on every wheel we skim. The set up piece in the picture visually highlights the problem beter than on a wheel. This was simply manually cut, jogging in on the X axis.
    Any help would be appreciated...its driving me mad
    Aug 2018
    5
    Have you tried a different tool or checked the head stock bearings and made sure you got plenty of clearance on the face of tool so the swarf doesn't catch or build up also is it chipping and you are using ally tips in your tool
    Nov 2018
    I think you need check chip formation
    Did you try other cutting edge sharper?
