585,959 active members*
5,182 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    Aug 2016
    Exclamation Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    Right, so I am posting on behalf of my brother-in-law... he just started a new company, and has one of these lathe machines. I believe he has work to do on the machine for a client.
    The problem is, that he cannot get his Edgecam software to communicate with the CNC Lathe. He has a background in the industry, and has tried everything but nothing is working. It's definitely a cable/configuration issue, not a user issue. He has tried making up 2 new cables, and still not working.
    Does anyone know where he can find the RS232 pin mappings? The cable is a 9-pin (laptop side) -> 25-pin (lathe side)
    I assume there are also a bunch of config settings that one would need to have setup the same on both ends, we would need that as well?
    Thank you everyone, I hope someone here can assist
    Feb 2015
    82
    Re: Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    Hi Richard, not sure if this link will work.. if it doesn't try doing a search on here as there is a lot of info to be found.
    http://http://www.cnczone.com/forums...-software.html
  1. help Me with OKUMA OSP 500L-G
    By campro0210 in forum Okuma
    Last Post: 09-22-2010, 11:14 AM
  2. Ncnet lite Okuma 500l-g
    By roger_e in forum DNC Problems and Solutions
    Last Post: 05-29-2010, 12:32 AM
  3. Okuma 500L Lubrication Pump motor
    By stevier in forum Okuma
    Last Post: 03-04-2010, 06:10 PM
  4. Okuma CNC OSP 500L-G --- Cam Software
    By rajappa in forum Okuma
    Last Post: 06-18-2008, 01:21 PM
  5. Okuma CNC OSP 500L-G
    Last Post: 06-03-2008, 11:36 AM
