585,931 active members*
4,979 visitors online*
Results 1 to 9 of 9
    Aug 2016
    11
    Line too long error on wincnc controller
    Hello,
    I am a newbe to wincnc I used to work with komo routers with fanuac controllers
    but its been awhile. My setup is CAM TECH 52 SM with Enroute 3 and a wincnc controller.
    i purchase this second hand with no manuals. I have downloaded the manual and watched every
    YouTube video I could find. It has got me to this point. Which is the machine responds fine
    to all Gcode commands. I have found a couple of jobs that the previous owner left in the computer
    and they run fine other than the z axis. When I go the create my own job and import the file it gives
    an error message line too short. The Gcode files that I create are the same as the ones left in the computer. They start and end with the same commands.
    Can anyone out there give me any ideas on how I might fix this error?
    thanks
    Mar 2008
    1762
    Re: Line too long error on wincnc controller
    Can you post the line that produces the error?
    How about a screenshot of the actual error?
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Aug 2016
    11
    On wincnc it's line 1
    I have since used another program TPCWin software that came with my router that converts the file to an nc. Instead of tap. File and it will accept it and will run that file with no errors.
    My other problem is my z axis is all over the place. I need to learn how to set home positions absolute / local
    The machine will zero fine. I can touch the tool off to my work surface. Zero it and run the program. The z will not go to the proper depth. Most of the time it routes way above the work piece. (Gcode is correct)
    Thank you ISLAWW for your reply. Don't know if you can help me with the z
    The wincnc manual is so vague.
    1943
    Is the program setting a tool length from the tool table? Look for a G43, or G43.1.
    Mar 2008
    1762
    I was referring to the actual code that produces the error.
    Can you post the file?
    Aug 2016
    11
    Quote Originally Posted by 109jb View Post
    The nc file that runs there is no g54 or g 43 in the code itself.
    It's specifies on the controller
    Aug 2016
    11
    Quote Originally Posted by islaww View Post
    Here are the screen shots of the tap. File that will not run.
    Mar 2008
    1762
    My guess is that your file path name has too many characters in it. Some of those older versions had a smaller limit than todays versions.
    Steps to test:
    Create a folder in the root (C
    Copy your tap file to that folder
    Open/load the file and see if it runs from that location
    Aug 2016
    11
    That's it ISLAWW
    It will run the file now
    Thanks for the help
  1. wire size for very long 220 line?
    By Phooey in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2010, 12:47 AM
  2. Replies: 7
    Last Post: 01-12-2009, 06:35 AM
  3. Post for WinCNC Controller 2.1
    By tgramel in forum WinCnc
    Last Post: 03-31-2008, 11:56 PM
  4. BobCad with WinCNC controller 2.1
    By Scott V in forum BobCad-Cam
    Last Post: 01-17-2006, 08:23 PM
