586,009 active members*
4,826 visitors online*
Results 1 to 2 of 2
    Apr 2018
    20
    torch vibrates when moving slow
    hi everyone,
    i've noticed something with my plasma table,
    when cutting something with a "lower" speed the torch and torch mount vibrate.
    this is only noticeable when it's moving in both (x and y) directions.
    if i bump the speed up it gets way less worse.
    with a speed of 3000mm/min it vibrates alot (small fast vibrations)
    when i go up to 5500mm/min it's noticeable less
    this may sound weird but i'm not sure if it has servo or stepper motor,
    if needed i could take picture of the motor setup.
    is this something in the motor tuning or is it in the machine build up (not rigid enough)?
    or does anyone have a idea where the problem lies and could be solved
    thank you!
    Apr 2018
    20
    Re: torch vibrates when moving slow
    has nobody any idea's or suggestions what the problem could be
    here's a link to a video while the machine is running:
    https://mega.nz/#!GPJwwSIb!Bv8JHZdQe...uGR1rmypSnujMI
    some pics of mach3 setting for the motors:
    Attached Thumbnails Attached Thumbnails imgonline-com-ua-CompressToSize-b92mlrv3CIA266G.jpg   imgonline-com-ua-CompressToSize-BpWjqXXhq0nha.jpg   imgonline-com-ua-CompressToSize-bZo9VBvyLpRZ.jpg
  1. DC Servo Vibrates on Fanuc 6M
    By parametric.ms in forum Fanuc
    Last Post: 08-06-2022, 08:11 AM
  2. Replies: 0
    Last Post: 02-12-2018, 03:53 AM
  3. Swiss Citizen L3 moving very slow during cutoff
    By mackjordan in forum BobCad-Cam
    Last Post: 06-11-2015, 12:47 PM
  4. Motor just stalls and vibrates!
    By prcdslnc13 in forum Stepper Motors / Drives
    Last Post: 12-02-2010, 01:58 PM
  5. B axis moving too slow after tuning
    By hamooteh in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2010, 05:47 AM
