585,974 active members*
4,286 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Arrow spindle motor issue
Results 1 to 6 of 6
    I have an Arrow 1000 with the black Cincinnati Milacron drives. The problem happens when I turn the Spidle on at rpm range of 3000 or higher. I get the Alarm: Axes Drive ready signal missing and the machines power to the drives are not enabled any more. There are no faults shown on any of the drives. If I enable the power again and tell it to run 1000 RPM, the spindle will run. So basically I cannot run high RPM without the machine tripping out. I have swapped out the power supply and spindle drive with known good drives and it is the same results.
    Has anyone had this same issue or know of a component that would cause this problem?
    Dec 2013
    15
    Re: Cincinnati Arrow spindle motor issue
    I just had that error (Drive Ready Signal Missing). Replaced the I/O board and it's good as new.
    Thank you Chopsmitty! That was the fix!!
    Sep 2009
    99
    EDIT: PROBLEM SOLVED
    The transformer I was using with the machine was under rated resulting in the issue. Changed to a correct rating and now machine is working well.
    Original Message:
    Dear Precisionatl,
    How did you manage to fix this?
    I have recently purchased an Arrow 500 from the US and brought it into my factory in India. I've got the machine running, but if I try to exceed 2000 RPM on the spindle the system gives the same alarm as you were facing and the machines stops working.
    Any advice would be appreciated! Thanks in advance!
    Best regards
    Jaideep
    Sep 2009
    99
    Just to update everyone- I managed to get the machine running OK a few days later.
    There were two issues-
    1.Turned out the spindle was mechanically trashed- we reconditioned it in house - cone grinding, new bearings etc and machine has worked well thereafter. This wasn't the real cause though
    2. The input step down transformer to the machine was under capacity and the voltage drop with the spindle acceleration was causing the drives to trip. A larger input transformer did the job.
    Oct 2011
    205
    Quote Originally Posted by jaideepshinh View Post
    Glad you got it fixed. I visited a cnc shop in Delhi on my last trip to India. Was interesting to see the summaries of the shops in India and Canada.
  1. CINCINNATI ARROW 500 SPINDLE ORIENTATION PROBLEM
    By andrez_gr in forum Cincinnati CNC
    Last Post: 07-23-2015, 10:05 PM
  2. Cincinnati Arrow motor or drive problem?
    By pmcg in forum Cincinnati CNC
    Last Post: 05-04-2014, 08:31 PM
  3. arrow/sabre/lancer Cincinnati spindle motor
    By mike_Kilroy in forum Cincinnati CNC
    Last Post: 04-07-2011, 01:26 PM
  4. arrow/sabre/lancer Cincinnati spindle motor
    By mike_Kilroy in forum Want To Buy...Need help!
    Last Post: 04-06-2011, 05:15 PM
  5. Cincinnati Arrow 500 Spindle Drive wiring
    By professor in forum CNC Machining Centers
    Last Post: 11-24-2007, 02:47 AM
