585,974 active members*
4,286 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Tsugami S25, Fanuc Control trying to program a negative radius.. I need help please!!
Results 1 to 8 of 8
    Jul 2016
    7
    I am using a tsugami S25 lathe to make a 2" long Dowel Pin. I am using material that is .505 in dia. and I have the radius on the front programed and its working fine. I am not turning down the Dia at all. On the back side I am using a cutoff to do a plunge cut. then pull the material in a little and finish the negative radius. I have the radius programed but I cant get the correct length on the radius
    :7000( 8/3/16 S25)
    M8
    G0G20G40G97G99T2100M11
    G110G28
    G300X.100Z2.287B6.693T1707
    G50X.100Z-.010M10S5200
    G0X2.200Z-.050
    T1303M13G96S300
    G0X.822Z-0.01
    G1X-0.030F.0015
    G1X.386F.0058
    G2X0.510Z0.070R0.125F.003
    G1Z2.0F0.05
    G4P100
    T1707M03G96S300(C-O)
    M8
    /M56
    /M58
    G50W-.087S3000
    G0X.605Z2.0 (OAL)
    G1X.400F.001 (plunge cut)
    G0X.605 (cut off backs out)
    Z1.75 (pull material back in for radius)
    G1X0.490F.002 (bring cut off close to material)
    Z2.0F.001R-0.095 (apply radius) I cant get the length to 0.062 the current length is .038
    X0.300
    /M21
    /M56
    /M53
    /G110G0B2.5
    /G110G1B.300F50.0
    /G141
    /M20
    /M58
    G1X0.30F0.001
    G1X-0.03F0.001
    /G140
    M5G97
    I appreciate any help I can get..
    Feb 2011
    353
    Re: Tsugami S25, Fanuc Control trying to program a negative radius.. I need help plea
    M8
    /M56
    /M58
    G50W-.087S3000
    G0X.605Z2.0
    G1X.400F.001
    G0X.605
    Z1.75
    G1X0.490F.002
    Z1.98F.001R-0.095
    X0.300
    /M21
    /M56
    /M53
    try writing it like this
    M8
    /M56
    /M58
    G50W-.087S3000
    G0X.605Z2.0
    G1X.400F.001
    G0X.605
    Z1.75
    G1X0.490F.002
    Z1.885
    G2X.300Z1.980R.095(you were still in g01 mode instead of g2/g3)
    (not sure of the age of the cnc control but i have programed an s25 d the age of the control is about 1995 fanuc)
    /M21
    /M56
    /M53
    Jul 2016
    7
    First let me say thank you for taking the time to help me. I am including a picture of the part and the cut off tool im attempting this radius with. The first radius on the front of the part is a positive radius but your saying i can put a positve R on the back side even though my tool is going in the negative?
    Feb 2011
    353
    The first radius on the front of the part is a positive radius but your saying i can put a positive R on the back side even though my tool is going in the negative?
    G2 is a clockwise arc
    G3 is a counterclockwise arc
    this is always a direction not a positive or negative value of the x or z
    if you start at the beginning of the arc and follow it to the end of the arc it will be clockwise (G2) on the front side
    on the cut off side if you do the same thing you will find that it is traveling in the same direction (clockwise)G2
    Jul 2016
    7
    Quote Originally Posted by rcs60 View Post
    I will surely try this Monday Morning. Once again I thank you for your help
    Jul 2016
    7
    Rcs60, thank you for your help! That worked and if I have any questions in the future I hope it's ok to look you up. Thank again.
    Feb 2011
    353
    your welcome for the help glad i could help you and it's ok to look me up if you need some help
    rcs60
    Dec 2010
    Do you have manual of tsugami S25 ,If have please send to me ---> [email protected]
    Thank you very much
  1. Using solidworks to help program BW12 Tsugami lathe
    By pleasedontcrash in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2016, 04:39 PM
  2. Help, Anilam Z axis takes off in the negative during program.
    By machining fool in forum DNC Problems and Solutions
    Last Post: 08-30-2015, 06:39 PM
  3. How to control A axis rotation in negative direction?
    By MaNo in forum Mach Software (ArtSoft software)
    Last Post: 08-25-2012, 04:56 PM
  4. Replies: 4
    Last Post: 06-15-2010, 03:38 PM
  5. Replies: 1
    Last Post: 01-23-2009, 08:37 PM
