Hi all,
Is there a way to clear the previous owners tool dia. and length offset data on our Okuma VMC with 7000M control?
Carl
Hi all,
Carl
Yes, press SET and write 0 and press ENTER key.
"Imagination is more important than knowledge."
Going from memory I think it was TLCLR then enter on the command line.
Experience is what you get just after you needed it.
I think you are in the right area,
Not sure if this would do as you ask
reference..... Okuma_OSP7000M_Operation Manual_3754-E-R2 (ME32-069-R3) (page 52) "Clearing/Setting Tool Numbers"
In the DATA SET screen ... if you input TCAN <write>
- it cancels all the tool data
then use TSET <write>
it then sets the tools to match the pot # in the carousel.... ie T1 in Pot #1 etc
read this section, it ask for additional confirmation.....you need to know what the consequences would be..
