585,982 active members*
4,713 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Wich are the best filler for Epoxy?
Results 1 to 8 of 8
    Mar 2005
    269
    Hey guys, i was reading some nice posts about machines made from Epoxy and fillers like sand.
    I found that is possible to use calcium carbonate, dolomite, sand...
    Someone know wich will be the best combination to make an solid and not overweght machine using epoxy+fillers?
    Thanks in advance
    Re: Wich are the best filler for Epoxy?
    A few threads down, is a thread with 5000 posts which explains exactly what fillers to use, and in what ratios.
    Jul 2016
    12
    thanks
    Mar 2005
    269
    Thanks too much gerry. i read some of these posts a few days ago, will read it full this time!
    Sep 2012
    108
    The aggragtes and fines used in concrete (cement) can be used in epoxy granit. Large stones 10-15mm down to fine sands graded to fill the voides. Sharpe stones add strength but make it harder to mix and work. Density is around 2200kg/m3 less than aluminium.
    Mar 2014
    1131
    There are some different stones that can be used(?) in my area. These are;
    - Quartz sand:
    - A sand that is called "Silis" in Turkish. People use it on sand blasting.
    - Lastly some kind of black sand. It is used to decorate floor of aquarium/fish tanks.
    Would you use these as filler?
    May 2015
    34
    I used two grades of quartz sand, and biggest aggregate was something like on your second photo, river sand. 8% to 10% slow curing epoxy, not vibrated, hand compacted with tools, and eveyrthing went well. Got the density of almost exactly 2 kg per cubic dm. Make sure to dry it well, as some bagged quartz can be little wet.
    Oct 2016
    16
    Basalt is the hardest and should be the best option, i think. The weight should also be a benefit. However, i could not find basalt in all grain sizes, thats why i mixed basalt, marble, gravel and quartz sand.
  1. Need advice on filler/paint
    By Cheff in forum Momus Design CNC plans
    Last Post: 07-27-2013, 01:46 AM
  2. Filler Rod for Tombstone Project?
    By Kincade in forum Welding Brazing Soldering Sealing
    Last Post: 07-26-2013, 06:20 PM
  3. Two questions, bits and filler
    By Buzz239 in forum Engraving Machines
    Last Post: 11-06-2012, 12:53 PM
  4. 8020 Extrusions with Epoxy Granite filler?
    By reiyuki in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 02-12-2010, 09:10 AM
  5. Filler Rod for 4130?
    By Chris64 in forum Welding Brazing Soldering Sealing
    Last Post: 09-30-2007, 06:01 AM
