Hi Folks
Recent threads on gib adjustment etc make me think a thread on Tormach accuracy and how to measure it may be useful.
I start it off with a couple of basics most people agree on. Check the backlash with a dial indicator measuring traverse with fine steps - eg X + traverse. Now reverse the traverse direction and note the DRO movement before the indicator shows actual movement.
I gather from my trials and posts over the years that a lost motion of 0.0005" is very good, 0.001" is common, and 0.002" shows there is a problem.
But a even better way to check real world errors is to test machine a OD diameter test piece and measure it with a micrometer. (A 'vernier' caliper is too alignment and pressure dependant) But note, even this will not always measure symmetrical lobing errors. Better still to rotate it and indicate it eg on a V block or in the lathe to measure total out of round. This measures a real world combination of machine errors including backlash, flex, racking, oil film under vibration etc..
Here is this test done on my 2007 Tormach 1100 in 2008. showing a total out of round error of 0.025mm or 0.001"
Cheers Keen
