584,805 active members*
4,854 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > rotary scratches on Aluminium
    Jul 2016
    20
    I've only every milled aluminium with a spray mist/coolant/lubricant.
    Yesterday I used a machine that didn't have this and so splashed oil on everything with a paintbrush.
    Afterwards noticed that there was a lot of rotary scratching on the faces of the material.
    Was that because there was no spray mist?
    Or was it for some other reason (it's true the mill had a max rpm of only 3000 but slowed the feed accordingly as per Gwizard).
    Jul 2016
    20
    Re: rotary scratches on Aluminium
    Not getting very far with this! May I put the question another way?
    What factors increase circular scratching when milling Aluminium?
    And what can be done about it?
    Thanks!
    Jun 2010
    4252
    Sounds more like a worn cutter.
    Cheers
    Roger
  1. Replies: 4
    Last Post: 12-03-2011, 01:16 AM
  2. Anyone polish scratches from cd's/dvd's with your mill?
    By slashmaster in forum Benchtop Machines
    Last Post: 08-07-2009, 02:10 AM
  3. *scratches head* AutoCad to BMP?
    By ImanCarrot in forum Autodesk
    Last Post: 01-14-2008, 03:38 PM
  4. One Hand Scratches The Other
    By bean7795 in forum DIY CNC Router Table Machines
    Last Post: 06-30-2005, 05:48 PM
  5. Bad scratches Stainless Steel
    By whiteriver in forum MetalWork Discussion
    Last Post: 04-27-2004, 03:20 AM
