585,996 active members*
4,544 visitors online*
    Oct 2014
    15
    Sweet Miyano problems
    Hi Guys,
    I have recently installed a 1984 Miyano BNC 20 lathe with a Fanuc 3Tc control. It's a lovely little machine but the fleshy bit is useless.
    I can get the X & Z to "zero return" but I can't index the tool turret as the manual says I should. As I say, it's most likely me at fault but I was wondering if some kind person could go through the start up sequence for me? When the turret is indexed, what is the aim?
    I run an old Cincinnati Arrow 750 mill and am used to indexing the tool changer to tool 1 then referencing it with a button push. I guess it's a similar process.
    Any help would be gratefully received.
    Pete.
    Re: Sweet Miyano problems
    The Turret should be able to index when the Hydraulic pump starts and runs. Then you should be able to index the Turret manually in Jog mode straight away or after zero return X and Z axis in MDI and AUTO.
    Oct 2014
    15
    Many thanks for your response. I discovered a small door at the end of the control with an interlock switch in. If I switch this, it all works a treat! I've actually manged to program some simple parts so the panic is over.
    Thanks again.
    RHK
    Feb 2012
    42
    Pete, I have an 84 BNC-20. I sent you a message about manuals
  1. WHO has a sweet Z axis?
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 10-11-2010, 08:35 PM
  2. Just bougt at Miyano Lathe but have problems
    By blakemachine in forum Fanuc
    Last Post: 07-28-2009, 07:05 PM
  3. 1996 Miyano BND34S-2 Problems
    By Frazier&Son in forum DNC Problems and Solutions
    Last Post: 12-30-2008, 10:46 PM
  4. sweet
    By jrj5x5 in forum Camaster
    Last Post: 11-06-2008, 07:15 AM
  5. Got a sweet ballscrew
    By Zumba in forum Community Club House
    Last Post: 04-08-2006, 12:22 AM
