hi,
I salvaged some linear rails with integrated ball screws which seem to be extremely robust. It feels like the X-Y axes, which are bolted together, must weigh 60kg although a lot of that is housing.
I'm wondering if I could make a CNC mill with them, a vertical mill (similar to the Tormach 440) to cut aluminum, harder metals if possible (but not a show-stopper if harder metals not possible). Unfortunately this is my first CNC machine d.i.y. build and despite reading about them for years, I feel like I could be missing something obvious why these rails would not be usable. The only thing I can think of so far is that the separation between the linear ways inside either X or Y axis is small so I might have quite limited usable milling space due to the rails not being able to withstand much torque.
Does anybody have any thoughts on if they'd make for good rails for the intended machine?
regards,
Randy
Here's some additional info I found from the company making these rails:
MOLS 100.500/100.150 (x&y rails connected together)
Recirculating linear ball bearings
Covered by bellows for protection
0,05 mm auf 300 mm precision
Travel 500mm on the long rail and 150mm on the short rail ?
spindle "KGT 12x5mm"
built-in inductive end switches on both ends
~$6200 new
ERO-SPEED 2000S/100 (was on z-axis)
Ball screw
Travel speed at max: 20 m/min.
Repeat exactness: ± 0,01 mm
spindle "KGT 16x5mm"
Bearing number dyn.: 10700 N
Dyn. Load moment Mx: 90 Nm
Load moment My: 44 Nm
Load moment Mz: 44Nm
Travel 10cm I think.
(more specs here, p.18 under "ERO SPEED 2000SF", Page Not Found)
~$1500 new
