585,766 active members*
4,290 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tutorials > Part , slice or section a 3D part
    Nov 2004
    9
    Using bobcad v28 and cannot find a way to break apart a 3D object. I have a part that is too big to 3D print so I need to break it apart into 4 sections. There must be a way to do this. If not, I could draw the part into 4 sections but I then cannot figure out how to bevel only the outside edge of a circle.
    I used the extrude boss and draft angle to build the complete circle but I cannot bevel the outside edge when it is in quarters?
    Anybody that can point me in the right direction?
    Joe L.
    Nov 2004
    9
    Re: Part , slice or section a 3D part
    I got it! I finally found out how to work the solids-split commands and got exactly what I was looking for. Might not be the best way but it is good for now. Still cannot bevel one edge and extrude at the same time.
    Good for now.
    Joe L.
    Apr 2009
    3376
    A .bbcd file and we can probably figure it out
    You have to .zip it to upload it
  1. Replies: 2
    Last Post: 02-28-2016, 10:07 AM
  2. Replies: 1
    Last Post: 05-17-2015, 08:37 PM
  3. cant get rid of solidcam from a part created internally within the solidworks part
    By Nava in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-24-2013, 01:05 AM
  4. Replies: 11
    Last Post: 05-23-2007, 02:41 AM
  5. How to Slice a part into several Sections?
    By GisMo in forum Solidworks
    Last Post: 09-11-2006, 05:37 PM
