585,752 active members*
4,035 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Best wood for signs using 1/16 inch bits?
    Feb 2008
    263
    What is the best wood for signs using 1/16 inch bits? I'm making signs that have NYPD and FDNY badges on top of USA flags. I think that the best wood is poplar or maple. My woodworking teacher is a cheapskate who won't buy hardwood because hardwood cost more money than softwood. I tried putting polycoat on softwood before cutting but it didn't work. Letters usually have little pieces broken off. Is plastic better than wood?
    Re: Best wood for signs using 1/16 inch bits?
    The harder the wood, the better. Maple should be far superior to poplar.
    Jun 2012
    182
    The "best" woods would be African blackwood and pink ivory. Ebony splinters badly.
    p.s. Try a thin cut shellac to seal and harden soft wood fibers. Low viscosity epoxies work well also, but have longer drying times.
    Apr 2003
    540
    Quote Originally Posted by jeffmorris View Post
    Do some research on HDU high density foam board. You can get it from a number of vendors and they make an assortment of densities. I've machined it on both a CNC mill and a with a CNC router with excellent results. Machines very easily. None of the grain, splintering or defects (like small pieces breaking off) or expansion/contraction checking issues you have with wood. It costs more than most of the basic soft or hardwood choices but is what most sign companies use now days. If you bought a large sheet the cost may be comparable. Cuts easily with a table saw etc. I've seen some finishes and painting techniques that look exactly like wood if that is your goal. I know the first time I tried it, I got free samples through an online vendor. Don't remember their name, but I'm sure with a little searching you can find those that will send you some small samples of various densities to conduct some tests with.
    Apr 2014
    432
    Local hardware chain has the Foam Board ,thank's for the jog in memoryI may give some a go.
  1. Spouse wants to engrave wood signs with our 1100 can it be done?
    By CabinDigital in forum Tormach Personal CNC Mill
    Last Post: 01-13-2015, 01:00 AM
  2. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  3. Replies: 0
    Last Post: 08-31-2014, 02:19 AM
  4. making wood signs
    By nydheart in forum DIY CNC Router Table Machines
    Last Post: 03-31-2007, 09:15 PM
