Hi guys;
In need of assistance
Our Hyundai HiT-18 cnc lathe is having spindle start issues
press the start and after a random time 5-45 minutes the spindle will start; it will run the program; do all operations to completion until it hits a spindle stop command, It stops, the next part is loaded in the spindle;
Then another random amount of wait time before it re-starts.
When you input the start command, the console shows it is active, the direction light and speed indicator are active, no faults displayed
The motor drive board shows a ready state; after a random amount of time the drive board will make an audible vibrating sound (like a relay buzzing) once the relay clicks the drive board shows a run state; the spindle starts and runs; the program runs, machine functions normally until the next programmed stop
Siemen’s 840 controller:
The fault appears to be in the in Simodrive 611 motor control board {6SN1121-OBA12-0AA0}
An help appreciated
Doug
