585,996 active members*
4,725 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Aug 2009
    684
    Re: Coordinate System Rotation And Planes problem!
    Quote Originally Posted by amir_nop View Post
    Isn't this moving on all 3 axes????
    The machine does it easily!
    What's the difference?
    Attachment 330474
    Hi Amir,
    Just to clarify, the drawing you attached looks like it is showing a part of a helical slot. The circular component is true to the xy plane. The z motion is a separate linear motion.
    So in the three standard working planes, an arc, even as part of a helix, is only handled by two axes. Arcing in a non-standard working plane is a feature more commonly used on 5-axis machines I suppose. It could be an optional extra on your control but probably not worth paying for.
    So how are you going to program it?
    DP
  2. #22
    Aug 2016
    11
    Quote Originally Posted by christinandavid View Post
    Hi Amir,
    DP
    Thank you for the information, actually I kinda gave up, it really annoyed me! I was working on it for a whole week standing up to machine and change every line more than 10 times.
    And I'm not convinced yet.. how can our controls be that weak..??
    Anyway there is a way to get it to work and it is dividing arcs to polylines, a little macro could do that easily, maybe someday I wrote it. not on the mood and so busy at the moment :/
  3. #23
    Feb 2006
    1792
    It looks like a simple helical interpolation. Option on some machines.
  4. #24
    I've tried your sample with my CNC and I've got this result:
    something wrong in program ?
  5. #25
    Sep 2018
    10
    Quote Originally Posted by shineworld View Post
    I'd suggest looking into g17-g18-g19 commands for your specific use.
    CNC lathes by default typically arc with the X axis.
    So changing the selection might do the trick.
    Either that, or just code it manually
Page 2 of 2 12
  1. Coordinate rotation problem on MORI SEIKI TV40 MSC-802m
    By kpandy in forum MetalWork Discussion
    Last Post: 08-28-2014, 04:25 PM
  2. G68 Coordinate system rotation.
    By Ashish B in forum CNC Machining Centers
    Last Post: 01-07-2013, 11:14 PM
  3. Coordinate System Rotation G & L NumeriPath 8000B
    By western pa papp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-05-2011, 01:03 PM
  4. G68.1 Coordinate System Rotation Help
    By SwissPR0 in forum CNC Swiss Screw Machines
    Last Post: 02-03-2011, 08:29 PM
  5. G68 Coordinate Rotation System
    By ebigfoot2 in forum Fanuc
    Last Post: 08-13-2007, 01:33 PM
