585,948 active members*
3,699 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 220V spindle / VFD from 110V input?
Results 1 to 6 of 6
    Aug 2016
    Hi Everyone,
    I'm in the middle of putting together a cnc router and it's come time for me to choose a spindle. Since it's not going to be a production machine but more of a hobby project I'm looking at the ubiquitous chinese spindles.
    So my situation is as follows. I live in an apartment and only have 110V at my disposal, short of rewiring the stove (and making the girlfriend quite unhappy in the process). I mainly plan on doing foam, laser engraving (with a laser, not the spindle), wood and maybe some aluminum, so power is not too great a concern. Eventually I'd like to get into aluminum down the line but that will be when it's in a proper shop. One thing I'd actually like is an ER16 collet, which I can only find on >=1.5KW spindles. There are a few 1.5KW spindles which claim 110V 3ph, and some inverters that claim to take 110Vin and output 110V 3ph, but they don't seem to have ER16 collets, only ER11. There are other VFDs that take 110V 1ph and output 220V 3ph.
    So:
    1. Has anyone heard of 110V 3ph? Has anyone used any of these motors?
    2. Has anyone used a 110Vac in to 220Vac out VFD (e.g. High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin or http://www.aliexpress.com/item/NEW-110V-Input-220V-output-VFD-Inverter-2-2KW-spindle-driver-factory-direct-sales/32651676894.html)? That one claims to take 110V or 220Vac and output 220V 3ph @ 2.2KW. Let's set aside the fact it will take >20A @ 110V to get this power rating for a minute. Has anyone used this with 110V in to successfully drive a 220V spindle? Is it possible to limit the output current of the VFD to stay within the max input power available?
    3. Could you get a brand name 110V to 220Vout VFD that's rated at 750W (maximum i've found) and limit the current on it to successfully drive a 1.5KW 220V spindle?
    This is an example of the spindle I'm looking at: http://www.aliexpress.com/item/CNC-S...546780152.html
    Alternatively there are the DC spindles that have an ER16 adapter attached to them, but I'm not super keen on the noise from DC spindles... and all the other issues that come along with them. (e.g. http://www.aliexpress.com/item/ER16-...03715579.html?)
    Thanks!
    Nick
    Nov 2012
    1267
    Re: 220V spindle / VFD from 110V input?
    Something like Automation Direct GS2-11P0 (1.0hp/750W, single phase 110V input, three phase 220V output) will probably drive your 1.5kW spindle just fine until you load it enough to trip the current limit.
    But why buy a 1.5kW spindle and use it at half capacity?
    Sep 2011
    84
    A step up transformer can give you 220, single phase for input. You will trip the breaker if you go for full load however.
    Making chips, day by day
    Aug 2016
    Quote Originally Posted by CitizenOfDreams View Post
    I'm after an ER16 collet to be able to use 3/8" shank tools. I don't imagine routing foam or light cuts on wood would require the full spindle power. I intend to get a proper 220V drive when I've got the supply available to me.
    Do the VFDs have current limiting or just trip if current is exceeded?
    15362
    Quote Originally Posted by nplayle View Post
    The VFD Drives that are rated for 120v ac input 220v output have a doubler built inside, all VFD Drives have a Parameter to set the Amps, so not much to worry about your 1.5Kw will be set around 6 amps max
    You need to get the right size VFD for what ever Spindle you are going to run, 1 Hp vfd for 1,5Kw spindle is not going to last very long, the VFD needs to have a larger Ratting than the Spindle, a match works but is marginal
    Mactec54
    Nov 2012
    1267
    As far as I know, they just trip (shut off with an error) when the current limit is exceeded.
  1. K40 220V to 110V conversion, how?
    By 18111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2013, 09:24 AM
  2. Replies: 8
    Last Post: 07-11-2013, 01:19 AM
  3. Replies: 14
    Last Post: 05-23-2013, 07:59 PM
  4. Servo for spindle, with 110v input?
    By aarongough in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2013, 02:23 PM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
