585,902 active members*
5,227 visitors online*
Page 10 of 13 89101112
Results 181 to 200 of 251
  1. #181
    Dec 2018
    5
    Re: Help with Novusun NVEM control card
    Quote Originally Posted by DigitalDream View Post
    Pls see the attaching file.
    it is the DLL file, if you use the dll file pls follow the configuration of EC500.
    Because EC500 is updated from NVEM V2,they can share the same dll file.
    Welcome more questions.
    Digital Dream
    hi, the file you attached cannot be downloaded. though my NVEM is ver 1.1 ethernet and i really need to fix my softlimit and hardlimit problems. do you have update for these issues ???
  2. #182
    Apr 2017
    Digital Dream
    Hi....
    Thanks.... Do you have any update for NVUM v2 .?
    Regards
  3. #183
    Apr 2017
    Today I try running NVEM V2 with EC500 plugins.
    It's work great, Connection is very easy and fast.
    The machine run smoothly but auto square using A axis slave to Y axis still not working.
    Regards
  4. #184
    Sep 2018
    11
    Yes we are developer.
    For your problem,I think the problems maybe from interference.NVEM V2 works bad on interferences.
    Our new version try to solved the problem of the interferences.
    If you can leave your email I will send you plugin and configuration information.
    You can use the new Plugin to test again.
    Sorry I was busy these days.I will try to go on CNCZONE everyday to solve the problems.
    does NVEM support for servo motor? thanks in advance
  5. #185
    Oct 2011
    4
    hi milky could send me also the link for NVEM Driver _P (Released 23/05/2017)
  6. #186
    Feb 2019
    hi miky could send me also the link for NVEM Driver _P (Released 23/05/2017)
  7. #187
    Feb 2019
    Hello,
    can someone send me the new driver with the fixes on Limit and Homing switches? NVEM Driver _P (Released 23/05/2017)
    Thanks.
  8. #188
    Sep 2018
    11
    Quote Originally Posted by aliwahab View Post
    Hello,
    Thanks.
    Hi , I have same problem with my NVEM V2 .
    Sent from my i5E using Tapatalk
  9. #189
    Aug 2016
    Hi! I also want to get the fixed version of the DLL for NVEM v1. Are there any plans from the developer to make these corrections or I can forget about it and do not longer communicate with the controllers of this company?
  10. #190
    Mar 2019
    8
    please subscribe to my youtube channel.. i just posted on my G-code CNC PCB milling https://youtu.be/CNIyHB7awX4
  11. #191
    Mar 2019
    miky4u2
    I am running a USB NVUM4-SP using Windows 10.
    Could you please send me a copy of the latest .dll and/or driver?
    Is the latest still the NVEM Driver _P (Released 23/05/2017)?
    Thanks in advance
  12. #192
    Mar 2019
    Hi everybody,
    I have got (unfortunately) NVEM V2 ETH controller. Two days ago I tried to connect to it - with success. Motor Nema23 worked fine. But yesterday ma controller can't connect to ethernet.
    Two diodes orange and green flash about 7-8 second and stop for 1 second. On PC I have connection for 7-8 second and after this time connection stops.
    Has anybody the same situation with NVEM?
    Thanks for any answer.
  13. #193
    Feb 2019
    I also need help with NVEM V2 ETH controller.
    It does not connect to my router. I have tried different LAN ethernet cables with no success.
    And when I check the log of the router no request for an IP has been received.
    Anyone had similar problems?
    Thank you
  14. #194
    I HAVE ALL SOLUTION OF CNC ROUTER DSP/24V CARD AND ALL TYP OF DSP
    ANY QRY CONTACT ON call or whatsapp +91 9376126262 / +91 8849665761
  15. #195
    Some issues found in my board:
    - Homing / Limits -> The NVEM v2 controller can home two axis, the third axis get a "limit trigger" error. (Configured like the manual, just the positive limit trigger "X++; Y++; Z++;")
    - Spindle -> Mine NVEM v2 cannot set the right speed in Spindle, I checked the VSO output, I was getting 10.37V in 24k RPM. When i set 15k RPM in Mach3, I get 14.1k RPM in the Spindle.
    - Spindle 02 -> Very very slow ramp up. About 30 sec to get from 0V to 10V.
    - Probing -> Just Impossible to probe with this board, it's even difficult to explain how the probe is erratic.
    - SoftLimits -> don't work as well.
    Was a little difficult to configure in Mach, but you have to "allow the program to get internet connection" it's a setting in Windows Firewall. Configure the IP Address correctly and boom, it works.
    But these issues above get us crazy.
    Plugins tested:
    NVEM v2 is original, with "Lollete" stick.
    https://www.nvcnc.net/pdf/Novusun.rar -> Downloaded here.
    https://www.nvcnc.net/pdf/EC500-DLL_V1.rar -> Downloaded here (Told by DigitalDream that plugins works because EC500 is a updated of NVEM)
  16. #196
    Hello, I am thinking of using a DC Motor Spindle. I want to use NVBDL+ as the Spindle Driver and NVEM as the CNC Breakout Board.
    I want to control the Spindle Speed with PWM.
    What is the appropriate connection between NVBDL+ and NVEM?
  17. #197
    Feb 2015
    11
    Digital Dream
    i have problem with output port
    what should I check ?
  18. #198
    Jan 2017
    24
    I haven't been able to follow this thread for quite a while but I see an EC500 came out and a DigitalDream developer suggested to use the EC500 driver on the NVEM V2...
    My question is , is there anybody out there who has been able to use Soft Limits/slow zones and Slave Axis with either the NVEM V1, V2 or EC500 , or are they still selling those boards with un-fixed drivers ?
    Have they even fixed the 'Limits Override' problem at all ?
    Cheers
    Miky
  19. #199
    May 2020
    Buy this cnc controller: https://www.amazon.es/gp/product/B07...?ie=UTF8&psc=1.
    I can't get the axis movement to work with the keyboard or with the mach 3 MPG module.
    if I remove the Novusun.dll plugin it works, but the controller does not communicate with mach 3.
  20. #200
    Aug 2013
    6
    if you are connecting directly to the computer you need to change the network adapter on the computer to static IP 192.168.1.11
  1. Replies: 22
    Last Post: 08-02-2019, 03:05 PM
  2. DSP MOTION CONTROL CARD
    By jamienw in forum HURCO
    Last Post: 05-23-2013, 07:38 PM
  3. SMC 800 control card
    By noyloj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2009, 11:37 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
