585,712 active members*
4,198 visitors online*
Page 8 of 13 678910
Results 141 to 160 of 251
  1. #141
    Mar 2018
    7
    Re: Help with Novusun NVEM control card
    Quote Originally Posted by rappa View Post
    hello!!!
    i have the nvum v1.1 and it works, i think,
    after all my nvum is not work correct!!!! the probe is not work properly and the controller fail steps, the z moves is very fault....the jog and the home limits is work. i dont understand.... i will put the nvum in the side, what controller should i buy?????
  2. #142
    Mar 2016
    44
    Rappa, I put my ver2 aside too, there not reliable, very bad programming. I went with a C11GS and use the UC100 USB to pararell controller, everything is running great.
    Sent from my Nexus 6 using Tapatalk
  3. #143
    Jun 2013
    14
    Quote Originally Posted by carl1961 View Post
    Same for me...
    couple of posts ago I've documented my findings with the V2... many problems mostly related to probing, limits, general movement
    My V2 will be sent back once the new controller has arrived.
    I will use a UC300ETH from now on... lots of IO options, and direct 0-10V output for controlling a VFD
  4. #144
    Mar 2018
    7
    Quote Originally Posted by Masterdrive View Post
    Same for me...
    you will use any board to pulgin the UC300? i want to buy a usb UC300 but should use a board to connect... like this one [VIDOE]https://www.youtube.com/watch?v=h6ea0L0j4zU[/VIDEO]
  5. #145
    Mar 2018
    14
    Please Check our New 10" Touch Screen CNC Controller - Made in UK
    Kickstarter Link below
    https://www.kickstarter.com/projects...oject&term=cnc
    You Tube Link below
    https://www.youtube.com/watch?v=Z6soNUxN900&t=118s
    Some Photos Below
  6. #146
    Jun 2013
    14
    The UB1 definitely is one of the nicest boards to use with the UC300
    Unfortunately, it's also one of the most expensive ones.
    I will use a couple of cheaper boards connected to the 5LPG board (a DB25-1205, a ST-V2, and a C10S)
    Most of these already came along with my stepper motors, the C10S was a bargain a Eb**
  7. #147
    Oct 2008
    10
    Hi folks, I'am new at this forum. I have purchased a NVEM motion control card. I'd like to use it for my laser engraver machine. My laser is wired to the spindle out of the controller. The motion controller ignore spindle settings at Mach3 and it's takes a long time to spin up and down so my laser doesn't work properly when I use M3 SXXX and M5 commands.
    Is it possible to turn off spin up and down delays of the motion controller?
    Thanks in advance.
  8. #148
    Aug 2013
    NVEC400 controller card
    hi guys
    anybody got an email address for the manufacturer of this controller
    can not get any thig working
    regards
    rick
  9. #149
    Dec 2007
    hello!!!
    i have the nvum v1.1 and it works, i think, but the speed off the motor is 1/2 off that i put in the motor parameter.... for example i put 2000mm/min in the motor tuning and it outputs, on the G0, 1000mm/min, any one can help???? sorry for my bad English.
    Hello. I am Spanish. And I have the same version. Please contact me on [email protected]. Best regards
  10. #150
    Aug 2005
    Hi
    I received NVEM ver1 controller and I could not run stepper motors, only DRO in Mach3 moving, but all other signals works
    I encountered the same problem without answers
    https://www.cnczone.com/forums/contr...ml#post1998278
    Everything was done according to the instructions, so I tried everything I knew,
    Note: drivers and motors work with another controller
    Does anyone know anything about this, and how to solve this problem?
    Help please
    Best regards
  11. #151
    Aug 2018
    hi milky could send me also the link for NVEM Driver _P (Released 23/05/2017)
    appreciate milky. cheers
  12. #152
    Aug 2010
    6
    Hello All
    I wish I had read this post more thoroughly before I purchased my NVEM. Have just spent 5 days rebuilding my cnc machine, It was well overdue after nearly 10 years of use. Thinking that the nevm would be the latest and hopefully better stepper controller.
    Many grey hairs and frustration at the randomly changing inputs, outputs and drive directions. Completely rewired the machine knowing that I have had some issue at times with rf feedback. Thought I had that covered but maybe not?
    The machine is running now, but I have not been able to resolve the random home/limits set up, have decided to just run with the limits with no homing.
    The smoothstepper is really good when it runs, lots of power and smooth quiet operation.
    I have developed a deep distrust for the selling countrymen, I purchased through DHGate, I found them deceptive and rude, I will be closing my account after I consider if the NVEM is actually going to work with Mach3?
    Regards
  13. #153
    May 2015
    8
    Glad I read this have had the same issues. Ran fine for a few weeks then began to glitch. Will try re installing everything and see how I go.
  14. #154
    Aug 2010
    6
    Hi milky
    I would very much appreciate the new dll, I have resolved all my NVEM issues and only the home / limit issue remains, If this DLL fix's that problem then NVEM may be OK?????
  15. #155
    Apr 2017
    I'm thinking about getting one of the NVEM cards and I'm hoping that someone who has used the card could tell me whether the spindle index function works. The manual shows that there is a port labelled as Index but the example of how to connect it doesn't show it being used. Also, the Lollette site says "Nvem does not support spindle speed feedback?INDEX)" but this isn't mentioned on AliExpress. It seems odd to have a connection that is labelled as Index but state that it doesn't have this function.
    Thanks for any input,
    Jim
  16. #156
    Mar 2016
    44
    Quote Originally Posted by jlambier View Post
    Jim
    If you want a dependable cnc card don't buy this company stuff, I have a NVUM sitting on the shelf now because no firmware updates to fix homing issues. I went to CNC4PC and bought the c11s and never had any issues. The CNC4PC should have eithernet cards too.
  17. #157
    Jun 2015
    943
    You can get a UC400ETH or UC300ETH and some cheap breakout boards from CNC4PC for similar cost as the NVUM and at least those work.
  18. #158
    Oct 2018
    4
    Hi everyone
    Im totally new in CNC world, and as you may guessed I bought a NVEM v2 BoB.
    took me probably 4 hours to get it working but now I have control on my steppers
    but I can understand how to connect to a spindle
    I have Huayang 2.2kw inverter and I have no clue how to wire that thing
    spindle is now connected to inverter and works fine, now I need a connection between inverter and BoB
    can someone please help me out with that ?
  19. #159
    Quote Originally Posted by Aberun View Post
    Hi everyone
    Not understand BoB please explain your controller board ?
  20. #160
    Sep 2005
    1195
    Maybe only chinese can install nvew ... Its proven already their industry work !!!
Page 8 of 13 678910
  1. Replies: 22
    Last Post: 08-02-2019, 03:05 PM
  2. DSP MOTION CONTROL CARD
    By jamienw in forum HURCO
    Last Post: 05-23-2013, 07:38 PM
  3. SMC 800 control card
    By noyloj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2009, 11:37 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
