547,579 active members*
2,435 visitors online*
Page 12 of 12 2101112
Results 221 to 231 of 231
  1. #221
    Registered
    Dec 2017
    8
    Re: Help with Novusun NVEM control card
    Quote Originally Posted by Art_N View Post
    Hi guys!
    Unfortunately, I read this forum very late. I bought this controller - Nvum v2 4axis ... and am now trying to get it to work.
    1 problem - after 30 minutes of work, the controller has lost the bin file. I found the bin file and restored it to work.
    2 problem - after an hour of work, the controller stopped connecting to the computer!
    I think the firmware is lost.
    How can I restore the firmware?
    This sound familiar was same here but in an other sequence and other controller NVEM v2 4 axis instead of NVUM.
    I had your second problem first after 1 day of playing, I noticed the communication led (green Ethernet) on the NVEM blinked much
    slower as when working. Contacted the seller with a movie attached and received a new one but had to wait 5 weeks
    as nomore available from the EU warehouse.
    The second NVEM works like a "charm".
    Meanwile I purchased a spindle
    Aircooled 2,2 Kw 3phase 300Hz 18000rpm collet ER25 (didn't find ER25 400hz 24000rpm as aircoolled and ER25 was main goal, was not easy/cheap to find in this setup)
    Huanyang 2,2 Kw inverter mono phase 220V
    The spindle is controlable from Mach 3 with M3 and M5 commands without external relay as mentioned befor,
    just have to check if rpm is displayed correctly with external hand rpm unit
    Grammatical errors are for free as google translate was helpfull
  2. #222
    Member
    Apr 2021
    Hi guys!
    I had the connection issue too and wasn't able to fix it. I asked the seller to send another one...
    This board are really lame. The second one worked 10 minuts and gave me the bin file error.
    Do you have the bin file or now how it is called. I've looked trough the internet but I only found borken links.
    Please if you have the bin file send it to me!!! It is the last try I give to this board.
    Andreu
  3. #223
    Member
    Jul 2020
    Hi all
    not sure this is the correct place for this post
    My first time on this forum and can not see where to start a new thread
    I have NVEM ethernet controller, having problems setting up the spindle
    It is a DC motor type, so all I need to do is switch a opto isilated relay to turn it on.
    Can any give some advise on how this is done and maybe a wiring diagram.
    I have every thing elses working OK this is the last thing to get going
  4. #224
    Member
    May 2021
    Hi the bin file was there
    https://www.nvcnc.net/nvum.html
    for some reason the link does not work anymore. Let me know if you solve it as i need the bin file as well but cant find it anywhere .
  5. #225
    Hi Drulo,
    Would you happen to have a bin file that seller sent to you? I'm looking for the bin file for Nvum v2 also. Thank you.
  6. #226
    Is anyone have a nvum v2 bin file that i can download? My stopworking after update the firmware.
    thank you,
  7. #227
    Registered
    Dec 2017
    8
    to. IANR23
    Befor I got the vfd and spindle I used a fixed speed AC router, I switched the router by a 24V auxiliary relay board from Aliexpress as I operate the NVEM at 24Volt
    https://www.aliexpress.com/item/4001...27424c4don1PpV
    It can be done easier but I like to have it safe as the NVE(U)M is a delicate board to mess up.
    NVEM S-axis
    GND connect -24V from power supply and also to DC minus on relayboard
    VSO connect to +24V from power supply
    Index not connected
    Out 1 connected to IN on relay board
    Out 2 was not connected as no need to rotated CCW
    Mach 3
    Setup in config Spindle setup
    M3 for CW output 1
    If use of CCW M4 output 2
    Output signals
    Out 1 port 2 Pin1
    Out 2 port 2 Pin2
    You can also use other outputs but need VB to write macro
    for activation as no buttons available in Mach 3 fot those outputs
    Hope this could help but all connections at your own risk.
    All these info here I found on the net but took me some time
    to have it work properly.
  8. #228
    Member
    Feb 2010
    65
    I'm also looking for the .bin file for EC500/NVEC400, someone have them?
  9. #229
    Member
    Jun 2021
    3
    Hello. I also need .bin file for UC300 https://www.nvcnc.net/uc300.html, i try to update firmware with .bin file from here https://bulkman3d.com/resources/ (this is were i bought the controller) and now stop communicating
    with computer. Does anybody know how to reset to factory this controller.
  10. #230
    Member
    Jun 2021
    3
    Re: Help with Novusun UC300 control card
  11. #231
    Jan 2020
    hi guys I have original nvem bin, and novosun flash tool, can share it, send me an email 540lab -at- inbox-ru
    But I have to say, that I killed my NVEM with attempts of fixing bin problem. It was working fine out of the box, apart outputs, and when I needed them I decided to load EC500.dll plugin as written before by DigitalDream stupid developer, and immidiatly had a bin-file problem.
    Throwed nvem to real bin and ordered SmoothStepper (ESS), so wish you the same. I only sorrow about nvmpg, it wasn't that bad, hope to connect it to SmoothStepper.
  12. #232
    Registered
    Jan 2018
    927
    Quote Originally Posted by charlienguyen View Post
    thank you,
    Bin the piece of garbage and buy something else that has ACTUAL existing support.
    ESS or UC400eth or something like that.
  13. #233
    Member
    12832
    Quote Originally Posted by dazp1976 View Post
    The Nvum Boards work fine and are just as good as anything else in the price range, if you mess with programing the Board then this can happen to any Board that is programmable
    Try it with the ESS or any of the UCCNC products and the same thing will happen
    Mactec54
  14. #234
    Member
    Sep 2021
    Hi, Everyone i have a problem with my uc300 digitaldream, after some usb crashes i think about the frequent of inverter, now only give me a usb not recgnized, i check the chip stm32 its normal but the spi flash its empty, i already find a backup for the stm32f207vct6 but without the flash memory the chip stays in error. anyone have this dump from flash?
    Tks
  15. #235
    Member
    Aug 2021
    3
    Hello RuYuri,
    Do you have the Firmware for the NOVUSUM NVUM V2 ETHERNET 6 AXES
    Do you think it is possible to reactivate the NOUVUSUN controller ??
    thank you in advance for your return
  1. Replies: 24
    Last Post: 04-18-2021, 10:59 AM
  2. DSP MOTION CONTROL CARD
    By jamienw in forum HURCO
    Last Post: 05-23-2013, 07:38 PM
  3. SMC 800 control card
    By noyloj in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2009, 11:37 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
