585,987 active members*
4,200 visitors online*
Thread: 5x5 table
Results 1 to 7 of 7
    May 2006
    238
    5x5 table
    Just finishing a 5x5 table. I had some motors and a g540 so i decided to go with the mp3000 ethernet box. I also got the command cnc linux computer. Its a little weird not having Mach3 but i think its a good thing for the long term.
    DN
    Jan 2013
    76
    Re: 5x5 table
    Great looking table. Did you machine the gantry end plates yourself? Is the gantry cross piece extruded aluminum or steel?
    May 2006
    238
    Re: 5x5 table
    Thanks. I did machine the end plates. The gantry is 1/8 wall steel tubing.
    Sep 2011
    54
    Re: 5x5 table
    Dave, looks great! Is that a different gear rack, or a machined spacer between the rack and linear rail?
    May 2006
    238
    Re: 5x5 table
    Thanks. The rack comes from these guys PRO Gear Rack, 39" (1 meter) | CNCRouterParts. Its easier to install all the holes are pre drilled.
    Nov 2012
    64
    Re: 5x5 table
    I always like seeing your post's Dave, another top notch job!
    It was one of your first builds that gave me the inspiration to build my own machine 3 yrs ago.
    Jun 2004
    6618
    Re: 5x5 table
    I would like to se more about the water table on this build and to see how you like it and how it has worked out for you.
    Lee
  1. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  2. Replies: 0
    Last Post: 05-14-2014, 04:32 PM
  3. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 06:35 PM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
