Hello.
I was hoping some could tell me the best way to cancel G43 with no spindle movement on a Fanuc 18im 5-face bridge mill. Right now, I came up with is 'G49 G91 X#5081 Y#5082 Z#5083'. The #508* variables are the tool length offset value for each axis.
I've tried using G49 by it self, but then the spindle may want to move the value of the tool length offset for each axis, witch may cause the mill to crash when using the 5-face head/right angle attachment. And without canceling the G43, I can't use G68 to rotate my coordinate system without generating an alarm or properly positioning the head to the new work plane. I also dont want to use 'G49 G90 Z10.0000' because by not knowing the exact offset value, that may cause the spindle to crash in the part.
Sent from my XT1080 using Tapatalk
