Need a couple adapters to bolt some Nema 34's to a 23 bolt pattern. I have attached a DXF of the part, the units are MM. I need 2 pieces out of 5/16, 3/8 or 1/2" 6061 or 7075. Not picky. 0.2mm tolerances, raw finish is fine. If you need a dimensioned technical drawing I can do that for you, just let me know. I would like to have a fairly quick turn around, multiples of weeks will not work.
EDIT: RFQ Closed. Thanks all.
