I have a G540 - everything was fine, then during a project run, it just flipped out. i stopped it, I have a planet CNC USB controller Mk3/4 hooked to it, no matter if I move it manually or via software the z-axis will go in the right direction at first but then starts going the wrong way and is very sporadic. I have unplugged everything many times. I moved the plug from the y axis into the z axis port, it moved in the right direction, put the z-axis in the y-axis port and it was still doing the same thing. unhooked everything and blew it out, hooked up just the z-axis, now it hardly moves at all, again the plugging in the y axis in the z port, it moves in the right direction fine. the motor moves freely when no power.
any ideas on what I need to do to get back up and running properly?
thanks
