585,987 active members*
4,623 visitors online*
    Feb 2005
    69
    FSSB 926 Alarm
    The machine is a vertical lathe with a 16i Fanuc controller. It gets a 926 FSSB alarm about 2 times every shift. Has anyone else had this problem with a 16i controller? I searched FSSB and found another thread, but the replies were basically from the book, bad axis board and check fiber optic connections. We are swapping boards out tomorrow from another machine. Any help would be greatly appreciated.
    Nov 2003
    98
    I have seen this on 2 different machines. Both were fixed by replacing the Fiber Optic cable from axis control card to servo amps. I believe the axis control card will cause this also.
    Bob
    Sep 2005
    31
    This alarm our machine had to occur. You must to change the Amplifier board of servo.Then alarm will be clear all.
    Apr 2007
    Exclamation Fssb
    dear friends
    For FSSB alarm u should check the following elements.
    1.Optical fibre cable of cnc controller
    2.i/0 module, if possible replace with the next machine.
    3.power supply card of system monitor.
    5.24 v supply/ DC voltage(proper or any short)
    4.PSM contactor(if it is not actuating in time, dis will happen-den replace it)
    Feb 2006
    213
    Re: Fssb
    Sir,
    In my case 926 FSSB alarm comes as spindle load increase.
    without load no problem.
    I hv checked optical cables, 24DC SMPS, etc but no sucess.
    Is it possible due to linear scales too?
    As this mache having linear scales.
    kindly somebody help me.
    Quote Originally Posted by mithunrams View Post
    dear friends
  1. Systen Alarm 926 FSSB Alarm (please help)
    By Shady Bliss in forum Fanuc
    Last Post: 03-03-2017, 12:25 AM
  2. Star SB16D 926 FSSB Alarm??
    By swissdodger in forum CNC Swiss Screw Machines
    Last Post: 05-13-2013, 03:37 PM
  3. Alarm 926 FSSB
    By wanchai101 in forum Fanuc
    Last Post: 01-10-2012, 09:44 AM
  4. Fanuc 18i controller 926 FSSB alarm
    By FanucIssues in forum Fanuc
    Last Post: 05-05-2009, 01:24 AM
  5. FANUC 926 FSSB ALARM
    By sting_dot in forum Fanuc
    Last Post: 12-05-2007, 06:47 PM
