586,011 active members*
4,739 visitors online*
Thread: Ground Point
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    24221
    Re: Ground Point
    Installed many systems earth grounding the DC supplies common and have not had a problem, I set up a 1/4" tapped copper ground plate and take every earthed common to it.
    Together with equi-potential bonding.
    Per the PDF: The concept of Earth consists of one homogeneous mass that is electrically neutral, i.e.
    an equal number of negative and positive charges are distributed throughout the earth at any given time.
    Albert E.
  2. #22
    15362
    Re: Ground Point
    And how many Hobby user's can achieve this here on the Zone, you are talking a foreign language to a Hobby user, which only ends up with more problems, when they try and achieve a system that has an equi-patential bonded Ground system, what you did in the industry does not equal Hobby user, this is for dreamers only, you have been here long enough to know that
    Mactec54
  3. #23
    Mar 2009
    1982
    Re: Ground Point
    There is nothing complicated actually. Only the problem is the way of explanation. It depends on the level of understanding and education background. Up to now the best description of "grounding" and protective earth belongs to Siemens in my opinion. I recommend to learn. Covers almost all aspects of earthing, Very detailed.
    Contains no expressions like "returning to source" or so.
  4. #24
    15362
    Re: Ground Point
    Quote Originally Posted by Algirdas View Post
    If you are talking about Ac Power Earth Ground circuits then that would be correct, you are not going to find source being used in an Ac circuit, understand what is being discussed would help you understand why the word source is used
    Mactec54
  5. #25
    24221
    Re: Ground Point
    Agree!
    Good comment!
    Albert E.
Page 2 of 2 12
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
  3. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  4. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
