585,992 active members*
5,495 visitors online*
Results 1 to 6 of 6
    Aug 2016
    EDM wrong direction of eroding, no voltage
    Hello.
    I have EDM sinker SURE FIRST, ZPNC 408, 2014.
    For a few days in auto mode, when i start eroding, Z axis is moving up against down, and there is no voltage on electrode.
    In manual mode everything is fine, z axis moving correctly in both dierection. Finding Z working good.
    After pressing start, can be heard generator is working, all fans, etc.
    I checked all fuses, wires, cards, capacitorsand others It looks right, no damages.
    I am looking for some solution for this problem.
    Mar 2016
    325
    Re: EDM wrong direction of eroding, no voltage
    Did You input eroding depth with "- " sign?
    Aug 2016
    oczywiście
    Mar 2016
    325
    So try to input it without. IT can be interpreted as depth not as coordinates.
    Aug 2016
    I tried to change direction of eroding and jump etc, but the problem is not in the computer settings, it's working right.
    I suppouse, that there is something like broken relay or diode or just something easier, but hard to find. I was reading all electrical diagrams in maual, and one by one i checked all parts with gauge. Everything looks right. I wonder what it could be.right now.. Maybe some dust or cold soldering, but this machines has only one and half year.
    Mar 2016
    325
    Check if the table is not connected with any part of cover. (it should be isoleted from chasis).
    If not check if there is a circuit between big wire connected to electrode and table.. It seems that You may have short circuit in high amperage line.
  1. Cut off spindle direction wrong
    By WOTDesigns in forum Mastercam
    Last Post: 02-15-2016, 04:17 PM
  2. Y AXIS WRONG DIRECTION
    By cncbeastmaster in forum Haas Mills
    Last Post: 11-24-2014, 05:21 PM
  3. Mach 3 running the wrong direction
    By teamtexas in forum Mach Mill
    Last Post: 11-13-2013, 01:58 AM
  4. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
  5. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
