585,954 active members*
4,396 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Small, *vertical* metal bandsaw? cutting 12 ga 304 ss sheet...
Results 1 to 6 of 6
    I am doing a lot of prototypes in 12 gauge 304 stainless. Usually, in production, I'll have the parts laser or waterjet cut, but I want to be able to sketch a design at breakfast, and have it in hand by lunch. So, I'm thinking about a vertical metal bandsaw.
    * How hard will it be to cut 12 gauge stainless on one of these? I'm used to a 14" delta wood bandsaw.
    * I know about the 4x6 cheapie horizontal/vertical saws. They give me the willies looking at them when they are vertical. Is there another option without going to a $1000 14" vertical metal bandsaw?
    * I don't cut up lots of stock, so I don't think I will miss the horizontal aspect. Is there something else I'm missing?
    * Do you think I could take a 12" jet wood bandsaw and change the pullies to slow it down enough?
    * Any suggestions on blade?
    * Any other suggestions?
    Thanks!
    -Jeff
    Jan 2004
    3154
    You will not get your wood Bsaw slow enough UNLESS you do like we did on our first Vert saw, add a gearbox to get your SFM down to 150 - 250.
    You will want to use a 14 TPI (or so) blade that is a high quality bi-metal construction.
    You will also want some ear plugs - cutting sheet metal really sings.
    www.integratedmechanical.ca
    Thanks DB...
    I found a used 10" rockwell that is belt driven that I should be picking up today.
    I'm hoping it is belt driven from the stand so I can do a two stage pully reduction. I calculate I can get it under 200 SFPM that way.
    Would it help to double stick tape the sheet to a sheet of plywood for support while cutting?
    -Jeff
    Not to be a nuisance, but my Wilton band saw (Enco model #505-1372) has a range of 32-3000 SFM, and I've had little fun cutting thin stuff especially stainless!
    The rule is to have three teeth in the work at all times, so make sure you have a really fine blade!
    Eric
    I'm planning on getting a 24 TPI blade for it....
    If it works out, I'll do a web page article up.
    -Jeff
    Jan 2004
    3154
    Well - not trying to stir anything up but IMO 2 teeth is proper engagement.
    You have to be careful with SS because it work hardens very easy. It is better to use a more agressive cut to help reduce the potential of this.
    Flood coolant will work, paste will make the chips stick to the teeth and cause problems (potentially broken teeth).
  1. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
  2. Bit recommendation for sheet metal
    By adda in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2007, 08:50 PM
  3. Horizontal metal bandsaw for home shop
    By jl123 in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2007, 02:05 AM
  4. Tog Gun Construction From Sheet Metal
    By username132 in forum European Club House
    Last Post: 01-15-2007, 02:11 PM
  5. Small 4 axis CNC bandsaw
    By BALLSCREWPRO in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2006, 07:28 PM
