586,009 active members*
4,880 visitors online*
Thread: Gecko drive
    Jun 2016
    Gecko drive
    Help trouble shoot gecko 320x when I turn on z axis wants to take off and run constantly
    Jan 2011
    188
    Re: Gecko drive
    did you check the encoder per step 3 in the instructions (before connecting the motor)
    it sounds like the encoder isn't working - could be defective or lost power or bad wiring or bad connector to the encoder
    www.signtorch.com
    Jun 2016
    [QUOTE=SignTorch;1930780]did you check the encoder per step 3 in the instructions (before connecting the motor)
    it sounds like the encoder isn't working - could be defective or lost power or bad wiring or bad connector to the encoder[/QUOTE
    This is not during initial set up been running machine a while we will check this out although it still does this with encoder unpluged
    Re: Gecko drive
    That's what happens when the encoder is not working, Unplugging it is the same as it not working.
  1. Do I have a bad Gecko Drive?
    By aaronbee in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-06-2015, 12:11 AM
  2. Servo Drive Selection Dugong vs. Gecko drive
    By native34 in forum Servo Motors / Drives
    Last Post: 02-06-2015, 04:37 AM
  3. Gecko Drive
    By Don Kellogg in forum DIY CNC Router Table Machines
    Last Post: 08-10-2008, 06:12 PM
  4. 320 gecko drive
    By Ed Williams in forum Gecko Drives
    Last Post: 05-19-2008, 06:20 AM
  5. Which Gecko Drive
    By Lloyd in forum Gecko Drives
    Last Post: 05-31-2006, 07:35 AM
