586,011 active members*
4,097 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Looking for a Ciizen Cincom F-Series cnc program
Results 1 to 8 of 8
    Apr 2012
    4
    Hi im looking for a few sample programs for a Citizen Cincom F-12 or an F-25
    Aug 2016
    29
    Re: Looking for a Ciizen Cincom F-Series cnc program
    I run an old (1984) Citizen F-20, if that'll help. Twin turret single spindle, live tooling.
    Apr 2012
    4
    Yes that would help
    Aug 2016
    29
    Ok. I'll pick a couple and send them to you Monday. I'll try and comment them out as best I can. I don't know about your controller but ours won't allow man-readable comments.
    Apr 2012
    4
    Thank you
    Aug 2016
    29
    Good morning JD. Here's the code for a simple aluminum tube we make on our F-20:
    O0200
    M52 (CHECKS TO SEE IF COOLANT ON)
    G20 G97
    G69
    M7 (OPEN CHUCK)
    G04 U0.5
    G98 G1 W-0.759 F100.0 (PULL PART OUT)
    G50 X0.0 Z-0.010 T0 (RESET ZERO TO -0.010)
    M6 (CLOSE CHUCK)
    G04 U0.5
    G69 (UPPER TURRET)
    G0 X-2.000 Z-0.100 T0 (UPPER TURRENT INDEX POSITION)
    (CALL UP TOOL 12)
    G99 T1200 S3000 M3
    (T12 LOADS THE OFFSET FOR TOOL 12)
    G0 X0.400 Z0.0 T12
    G1 X0.000 F0.007
    G0 Z-0.100
    G69
    M1
    (CALL UP TOOL 13)
    (90 DEG SPOT DRILL)
    T1300 S3000 M3
    G0 X0.000 Z-0.100 T13
    G1 Z0.110 F0.004
    G0 Z-0.100
    G69
    M1
    (CALL UP TOOL 14)
    (0.218 DRILL)
    T1400 S3000 M3
    G0 X0.000 Z-0.100 T14
    G1 Z0.400 F0.004
    G0 Z-0.1
    Z0.380
    G1 Z0.600
    G0 Z-0.1
    Z 0.580
    G1 Z0.725
    G0 Z-0.1
    Z0.715
    G1 Z0.775
    G0 Z-0.1
    G68 (UPPER TURRET)
    G0 X8.500 Z-0.100 T0 (UPPER TURRET INDEX POSITION)
    M1
    (TOOL 24, BORING BAR)
    T2400 S3000 M3
    G0 X0.2243 Z-0.100 T24
    G1 Z0.715 F0.004
    X0.215
    G0 Z-0.100
    G69 (LOWER TURRET)
    G0 X-2.000 Z-0.100 T0 (LOWER TURRET INDEX POSITION)
    M1
    (TOOL 12, TURN O.D.)
    T1200 S3000 M3
    G0 X0.400 Z0.000 T12
    G1 X0.200 F0.005
    G0 Z-0.050
    X0.2854
    G1 Z0.000
    X0.3143 Z0.014 F0.0015
    Z0.750 F0.007
    X0.400
    G68 (UPPER TURRET)
    G0 X8.500 Z-0.100 T0 (UPPER TURRENT INDEX POSITION)
    M1
    (TOOL 23, PART OFF TOOL)
    T2300 S3000 M3
    G0 X0.400 Z0.749 T23
    M32 (PARTS CATCHER OUT)
    G4 U1.50
    G1 X0.280 F0.004
    G0 X0.350
    Z0.740
    G1 X0.3143
    X0.2963 Z0.749 F0.0015
    X0.200 F0.002
    X-0.100 F0.003
    M33 (PARTS CATCHER BACK)
    G69
    G0 G28 U0.0 W0.0
    G50 X0.0 Z0.0 T0 M5
    M2
    Hope it helps. I'll answer any questions I can. Good luck!
    -aj
    Apr 2012
    4
    Thanks for the program, it helps a lot. there's a machine shop I sometimes work part time hours at has an F12 and F25 and my full time job has has lathes and mills. I'm hoping to get my programing skills up to par.
    Feb 2019
    14
    Hello.. We are looking for parameters of Citizen L20 5-axis CNC Swiss Sliding Head Machine with Mitsubishi Medlas 300 control from 1997.
    Let me know if anyone could provide us with it.. Thanks Regards
  1. Loading a Program in Citizen L20 Series VII
    By Satchmopants in forum CNC Swiss Screw Machines
    Last Post: 01-12-2015, 01:58 PM
  2. Program manual required for Series 21i-m
    By CNC-Hammer in forum Fanuc
    Last Post: 12-26-2014, 05:30 PM
  3. Series 5 Lathe program
    By SKENEY in forum Fanuc
    Last Post: 07-15-2012, 11:39 PM
  4. copy program on fanuc series O or OT
    By cuz1007 in forum Fanuc
    Last Post: 01-27-2010, 07:57 PM
  5. Series I with Heidenhain 155 Won't run program
    By dbcooper99 in forum Bridgeport / Hardinge Mills
    Last Post: 10-16-2007, 07:56 PM
