Anyone want to play a game?
"Let's guess what the end diagnosis is".
My 440 is having a problem with what I've been calling "x-axis slipping". I'm working with Tormach, but I figured it might be entertaining to take bets as to the final cause. To be clear, I'm going to go through the support process with them since there's obviously something ****ing whacky hardware wise, so you are just spitballing...
TO MAKE IT MORE INTERESTING, ONCE IT'S FIXED THE FIRST PERSON WHO GUESSED RIGHT WILL GET A PRIZE... I'll buy you a Tormach Tshirt or 2 of their coffee mugs ( one for you and the significant other in your life... be it wife, girlfriend, coworker, dog... no judgement here ). US Only.. sorry, not willing to pay international shipment...
I'm bored, and it's not a problem I've seen in any other video, so I figure it will make an interesting guessing game.
First, let's see it in action ( I recommend turning your sound down ):
https://youtu.be/34zb0UwXzBA?t=15s
( jump to around 15seconds since the forum isn't respecting the time code )
Anyway, it starts doing parallel passes then in the middle of an X move, it freezes with a "buzzing" noise coming from the motor area, the MACHINE THINKS IT'S MOVING, and then at the next change in direction i starts moving again ( with interesting effects as seen in video one where it plows through the material ).
It happened 3 times on the 22nd, with it working fine for a bit in between ( 2 or three operations ).
It happened on both an XPositive ( operator left to right ) and a XNegative move ( operator right to left ). ( Instance 2 was moving left to right, instance 3 right to left )
The third time I captured it in the video above.
Entertaining, no? That was a very nice piece of hybrid stabilized wood that was destroyed... about $15 in materials and 10mins on the backside ( this was the second operation ) down the toilet.
Now, if you were listening, the compressor kicked in right before.... The compressor and the machine share the same surge protector ( a Tripp-light ) and I have a dedicated 20 amp circuit with the machine, compressor, and controller on it.
Electrical noise/interference?
Nope...
This is NOT related to my compressor. I was able to replicate it with nothing but the CNC and the controller plugged into the circuit and surge protector.
https://www.youtube.com/watch?v=9Kwf...utu.be&t=6m45s
( jump to 6m45s since the forum doesn't seem to be respecting the time code )
Replication Steps:
- Get a 440 with the new controller and flood coolant kit in it
- Follow the standard start procedures ( controller, power, estop, green button, reset on pathpilot )
- Ref X, Y, Z
- Load up a dirt simple gcode file ( my test file is a facing pass with 0.5mm y-stepover so it does lots of passes in a smaller amount of space )
- Stick in a tool
- zero the machine somewhere in mid air with 50mm usable x distance on both sides, and 25mm usable on both sides of the y axis ( the origin is centered in a 100mm x 50mm space in my test file )
- Run the file
- Wait for it to happen
And, here is where my "good user, reporting problem WITH test and replication steps" breaks down.
The problem is intermittent, in the video above, it happened at around 6:45 or so... I ran the program a second time for the full run ( 18mins ) and it didn't occur.
Some more information:
The spindle does NOT need to be running for it to occur, I've replicated it with the spindle off and only doing the moves.
https://www.youtube.com/watch?v=DMygy9nfIiM&feature=youtu.be&t=25s
( jump to 25seconds since the forum doesn't seem to be respecting the time code )
The "gross" slipping buzzing is not the only thing occurring. In the video uploaded on this one, if you listen closely you can hear it doing smaller versions of it ( buzzing ) and stutter stepping.
The first possibility from the engineers at Tormach was the coupler between the X-axis motor and the ballscrew being loose...
This ( of course ) caused me another problem with one of the screws holding the cover plate on rounding out on me... I ended up ordering a pretty cool set of bolt/screw extractors, drilling it out and extracting the screw ( saving the threading in the housing )
Anyway, today the set arrived and I got the screw out. All 4 of the coupler bolts were/are "hand tight"... there was zero play in them at least up to the point that I could hand twist with a T-Handle. I didn't risk putting any more torque on them then what I could do with my hands, but I imagine that if it didn't move then, it was plenty tight... will find out from Tormach Monday probably.
So there we are... I just emailed Tormach ( it's a Saturday, so I'm not expecting to hear back from them anytime soon ) and figured we could play "let's guess what it ends up being".
I'm happy to answer any questions, but not going to do anything with the machine without express directions from Tormach, so no physical tests... sorry.
