584,866 active members*
4,986 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > MasterCAM Machine & Control definitions for X2 CNC conversion
Results 1 to 7 of 7
    Feb 2014
    Hey guys,
    I was wondering if anyone out there is using MasterCAM and Mach3 with their X2 CNC conversion. I just finished converting my machine awhile back and I am now in the process of learning how to program it, which has turned out to be more difficult for me than actually building it. I have access to MasterCAM X4 on a friends computer but of course it doesnt have the machine or control definition files for my specific machine and controller. I found the Mach3 post processor for MasterCAM, but only bits and pieces of information on how to create custom definition files. Would anyone out there be kind enough to share their definition files with me? I would greatly appreciate it. Thank you
    May 2013
    14
    Re: MasterCAM Machine & Control definitions for X2 CNC conversion
    Quote Originally Posted by jleworthy View Post
    Hey guys,
    Hi Im in the same boat, did you ever get your hand on the files? Any chance you can help me out? Thanks in advance.
    Jan 2018
    1516
    Quote Originally Posted by albert_chuy View Post
    Looking around it seems a fair few hobbyists have moved over to Fusion360. Might be worth having a play with that.
    As far as I'm aware you can get it free for hobbyists (don't quote me on that as Autodesk do not specifically say it).
    It apparently comes up in the license options at a later date.
    Feb 2005
    829
    You would have to build your own definition files and post processor. Mastercam does not create machine definintions and post processors for free, they sell them for thousands.
    Fusion 360 is free, but unless you are using a CNC conversion kit that included a control and steppers, you still will probably have to create your own post processor for a hobby cnc conversion mill.
    Aug 2009
    230
    Fusion360 does have a post for Mach 3 Mill. I don't know how well it works; because I don't use Mach 3 anymore (I'm working on a grbl-based system)... but they do have one.
    IIRC, the post-processors are written in Javascript; and are not that hard to modify if you have any programming ability whatsoever.
    As of right now; Fusion360 is free for startups, very small businesses, and 'enthusiasts'... which is the license I have for it.
    Hope that helps!
    1206
    Since the original post is almost three years old I suppose we can assume jleworthy has found a solution,he certainly doesn't post very much.I recall reading a few weeks ago that Fusion was modifying the free access to the software.I don't have any concerns about this since I chose to go with Freecad and LinuxCNC which keep growing in capability and are both free.Mastercam is a wonderfully capable program but hugely expensive for a hobbyist and Mach 3 is getting a bit ancient but still seems to pop up with basic Chinese machines.
    Jan 2018
    1516
    Quote Originally Posted by __Britt View Post
    Hope that helps!
    That was my understanding from various reading around. I would have assumed that Mastercam would plugin to Fusion would it not?
  1. Replies: 0
    Last Post: 08-16-2016, 09:09 PM
  2. VFD conversion for 0tc control
    By curtistdc in forum Fanuc
    Last Post: 01-05-2016, 01:33 PM
  3. Machine Definitions in metric?
    By cncadmin in forum BobCAM for SolidWorks™
    Last Post: 12-06-2013, 07:50 PM
  4. HAAS VF3 machine definitions for X7 SP2
    By daytona81 in forum Mastercam
    Last Post: 10-07-2013, 02:28 PM
  5. TurboCad Cam Tool and Machine Definitions
    By htishop in forum Uncategorised CAM Discussion
    Last Post: 11-01-2007, 09:08 AM
