I have a fairly early Torus Pro. I started with the "standard" base, but later swapped that out for a preproduction "Deluxe" base. This base is a big improvement over the standard one in terms of coolant drainage and chip collection, but is missing several improvements that are in the production version (some as a result of my feedback). While coolant drainage is good, chip collection is not as good as it could be, an cleaning the machine is still a nuisance, as chips get clogged up getting under the machine to the "chute" into the chip tray.
I recently made a minor modification that simply keeps all the chips up on top, where they are easier to remove. I have several large sheets of aluminum "diamond plate" a fried had given me, so I cut a few pieces to prevent the chips from going under the machine. A similar modification, using whatever material is handy, should work just as well for folks with the "standard" base to make cleanup easier.
Regards,
Ray L.
