-X toolpath generation for GT27 lathe
Hi all,
Newbie to Fusion 360, trying to warm up to it. The below might be a show-stopper.
My GT27 lathe, with gang plate, Fagor 8037 controller, has tools on both sides of the gang plate, hence, depending on which tool I use and where it comes from, I need tool paths generated in both +X and -X direction. I have done some basic research here, and I am getting the impression Fusion can't handle the -X direction as all paths are from +X, no matter how your tool is setup in the library. So, I saw one post calling this a simulation issue, but is bigger than this. Basically, I can't generate G code. If I do generate it, I am left with manually adding a "-" sign in all the X moves that need it....ripe for mistakes and crashes.
Can anyone confirm and is there a work-around? I suppose a custom post could be created somehow to say "if you are using tool #3, make all the X values -X values" or something like this. Seems clumsy, but maybe will work. Anyone want to try making a post like this?
Paul
Paul - milling since March 2012 - Solidworks/HSMExpress/Tormach1100 user
