585,959 active members*
4,036 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Ideal Water Temperature to Maintain For a Water Cooled Laser Tube?
    Aug 2016
    75
    Does anyone know this temperature number? I can't find one in my poorly written manual.
    Doug
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Feb 2009
    6028
    Re: Ideal Water Temperature to Maintain For a Water Cooled Laser Tube?
    Mine says 78 degrees max I think, and you want it above dew point. I shoot for 68-70.
    Sent from my A3-A20FHD using Tapatalk
    Aug 2016
    75
    Thanks for taking the time to reply.
    Nov 2008
    644
    Thats correct. My tube seems to cut with more power and accuracy at 15 C
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  3. Air Cooled vs Water Cooled Pros and Cons and Advice
    By Tundraman in forum Spindles / VFD
    Last Post: 06-20-2015, 08:41 PM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. Water temp, glass laser tube
    By Chad Veich in forum Engraving Machines
    Last Post: 11-22-2012, 06:00 PM
