584,802 active members*
5,071 visitors online*
Results 1 to 8 of 8
    Aug 2009
    13
    G0704 oiling system
    I am in the process of making my G0704 a CNC machine. I want to setup an oiling system for the ways and ball nuts. I have looked on this forum but haven't found exactly what I am looking for. I need some kind of layout to see where to plumb the oil lines. I think for what I have seen on the internet, I know how to do the X and Y, but dont see how to get oil to the ball nut on the Z. Any help will be appreciated.
    Mar 2012
    109
    Re: G0704 oiling system
    Your Z ballnut probably has a zerk fitting on it, to which you would run a lubrication line within your column. Where exactly do you think the problem lies with your Z axis? Can you give us some photos for context of explain your issue with a bit more detail?
    Dec 2012
    390
    Does anyone have some pictures showing how they routed the oil line for the Z-axis? I do have a zerk fitting on my ball nut, but how do I get the oil line inside the column without it being pinched when the Z-axis is moving up and down?
    Nov 2009
    4415
    Quote Originally Posted by Stigoe View Post
    Bring the lubrication tube out thru the head and route it with the spindle motor wires.
    A lazy man does it twice.
    Dec 2012
    390
    Quote Originally Posted by Fastest1 View Post
    Do you mean through the center hole (the original fastener hole)? Wouldn't the oil line be cut off when the head is at its highest (with the flipped head mod)? Currently, I'm using that hole for a fastener bolt, but I guess I can manage without it.
    Sep 2016
    46
    Does anyone know where to get more Ballscrew zerk fittings? Mine have been misplaced.
    1943
    Quote Originally Posted by DubMFG View Post
    Have you checked a hardware store or farm supply. The ones near me have grease nipples in various thread sizes as well as pressed in version.
    Dec 2012
    390
    You can also find kits of fittings on eBay for a few dollars.
  1. Improved Oiling System
    By SCzEngrgGroup in forum Novakon
    Last Post: 05-11-2022, 07:40 PM
  2. Lubrication Options/Oiling System Alternatives
    By Ron2d in forum Benchtop Machines
    Last Post: 03-02-2016, 04:43 PM
  3. PC 1100 oiling system
    By sperman in forum Tormach Personal CNC Mill
    Last Post: 08-24-2012, 10:39 PM
  4. One Shot Oiling System
    By imprez55 in forum Benchtop Machines
    Last Post: 07-14-2009, 01:27 AM
  5. Z not oiling!!!!
    By carbidecraters in forum Fadal
    Last Post: 07-07-2005, 02:26 PM
