584,865 active members*
4,983 visitors online*
    Jun 2010
    116
    Strange code issue!
    I was just running the following code and had a crash happen. I can't figure out why! It did the first section perfectly then got to the M01 position. After I hit start it moved to the x,y position but also moved in Z down into the part at the same time. Can anyone tell me why this would have happened?
    N100 (Machine Setup - 1 Center Drill)
    (RETURN PINS - 0.3760)
    T5 M06
    S681 M03
    G00 G54 X-3.5 Y0.75
    G43 H5 Z1. M08
    Z0.2
    G81 X-3.5 Y0.75 Z-0.08 R0.1 F0.9534 G98
    Y-0.75
    X3.5
    Y0.75
    G80
    G00 Z1.
    N102 (Machine Setup - 1 Center Drill)
    (CENTER EJECTORS - 0.2810)
    T5 M06
    M01
    S681 M03
    G00 G54 X0. Y0.875
    G43 H5 Z1. M08
    Z0.2
    G81 X0. Y0.875 Z-0.08 R0.1 F0.9534 G98
    Y-0.875
    G80
    G00 Z1.
    Jun 2010
    116
    Re: Strange code issue!
    OK, I figured it out. The tool change must clear the H value so it thought the tool was at the spindle not the actual length! Remove the M06 T?? and it works fine.
    May 2010
    54
    Hey I have a vm17 and plan to use fusion 360. Do you use fusion 360 with your partner 1?
    Jun 2010
    116
    Haven't heard of Fusion 360 before. Looks interesting. I use BobCAD, pretty happy with it so far although it's not as nice as MasterCAM that I use at work though!
    Jul 2010
    548
    I talked to a customer today, he is using Fusion 360 on his Mach 3 control. he seems to like it.
    We have not yet done a Milltronics post from it.
    It seems to hold some promise for "us" smaller guys.
    will it replace a 15K mastercam / surfcam / ???? most likely not, but for "Free" for under $100K users. "whuda got to lose" ?
    Try it and keep " US" informed, changes to the POST??? keep "US" informed.
    for machines without a tool changer try the Fanuc, M6 or M10 Post., LET "US" know.
    sportybob
  1. strange emco 325 issue
    By ratedr in forum EMCO Lathe
    Last Post: 11-20-2016, 04:29 AM
  2. Strange Issue? Maybe?
    By cotang in forum Uncategorised WoodWorking Machines
    Last Post: 04-14-2014, 05:37 PM
  3. Strange Z backlash issue
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2013, 11:50 PM
  4. Strange issue with a C10 BOB
    By Brass_Machine in forum Automation Technology Products
    Last Post: 04-27-2011, 12:32 AM
  5. Strange MAzatrol / EIA-ISO issue
    By SPE_user1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-09-2008, 02:10 PM
