585,974 active members*
4,263 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Guitar neck and heel transition
    Sep 2013
    131
    Hi all, I have Catia and Mastercam, and need to know the best approach on making the neck and heel look like they are suppose to. Thank you for your help.
    Mar 2008
    683
    Re: Guitar neck and heel transition
    Trim your neck back to the nut. Then trim an inch of two of the headstock. Face Loft with tangent continuity. If that doesn't work. Break the solid models in to smaller parts. Loft 1/2 of the neck to headstock then the other half. Lofting edges or face to face will give you some nice blends.
    Sep 2013
    131
    Thank you very much, Warren.
    Sep 2013
    131
    Ok, so I got most of it, I just have a trouble area that won't smooth out, any help would be great. Thank you all.
    Sep 2013
    131
    I got it fixed, just had to redraw the radius and extrude it.
  1. Replies: 6
    Last Post: 03-25-2021, 10:01 AM
  2. 2 RAIL or something else for this Guitar Heel
    By poolrod2 in forum Mastercam
    Last Post: 03-17-2015, 03:17 AM
  3. How do you make the transition from the heel in Rhino3D
    By dinkyguitar in forum Musical Instrument Design and Construction
    Last Post: 01-22-2013, 10:00 AM
  4. OYE! Need help on 3D neck transition
    By wbegg in forum Musical Instrument Design and Construction
    Last Post: 10-06-2011, 05:37 PM
  5. Need Neck Heel digitized
    By robinsoncr in forum Musical Instrument Design and Construction
    Last Post: 01-30-2007, 11:04 PM
