584,808 active members*
5,235 visitors online*
    Jun 2013
    Fadal VMC 4020
    Hello all members,
    I have a question to forum.
    Our factory purchased CNC machine: FADAL VMC 4020.
    If possible change on this machine milling tool orientation from vertical to horizontal. We need this for tap 1/2 NPT hole on extrusion profile which 36" long.
    Stanislav
    Mechanical Designer.
    Jan 2015
    417
    Re: Fadal VMC 4020
    G17 maybe . not sure i understand the question?
    Jan 2015
    417
    Re: Fadal VMC 4020
    or possibly this is a format 1 or format 2 question........ Q value.. in the SETP format 1 uses the Q for the pitch for example 1/4-20 it would be Q.05 with F as the rpm..... where as with fanuc a 700 rpm would have a F35. commonly
    Jan 2004
    3154
    Re: Fadal VMC 4020
    I am going to go with neither Rodney and suggest that what they want is a right angle milling head and compression/tension tapping tool
    www.integratedmechanical.ca
    Jun 2016
    57
    Re: Fadal VMC 4020
    Quote Originally Posted by slavasp View Post
    Hello all members,
    Stanislav
    Yes you would need a right angle milling head and floating tap holder..
    But this will cost near what the machine is worth; they are very expensive. If there was a large quantity, get a flex arm tapper. If necessary you can drill/ ream on a floor model drill press.
  1. Fadal VMC 4020
    By reececup99 in forum Fadal
    Last Post: 05-09-2012, 02:09 AM
  2. Fadal 4020
    By ghm195 in forum Fadal
    Last Post: 04-23-2012, 06:17 PM
  3. Fadal 4020 mm/um in MDI
    By hartan in forum Fadal
    Last Post: 12-20-2011, 10:50 AM
  4. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  5. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
