585,949 active members*
4,166 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > With Modifacations in Steel and Aluminum.
Results 1 to 8 of 8
    JGRO MODIFICATIONS IN STEEL AND ALUMINUM.
    I am using 1 1/2" angle for the base and 3/4 " angle for the middle supports.
    Instead of using 3/4 mdf I am using double sided aluminum plywood 1/2 " ( $130.00 per sheet 4x8' ) I will use steel brackets in some places to make up for the lost 1/4 " when using 1/2 plywood instead of 3/4..The rail adjusters are made from 1/2 " aluminum plate. I am going to change from head screws to set or grub screws on the rail adjusters.
    Please do not copy any design changes I have made until I have verified that all my modifications will actually work as made, Thanks
    Some times you have to back and change stuff...:
    Here are some photos of the build so far.
    Attachment 333660Attachment 333662Attachment 333664Attachment 333668Attachment 333670Attachment 333672
    Don't Give Up The Ship !!!
    Re: With Modifacations in Steel and Aluminum.
    Here are some new photos.Click image for larger version.
ID:	333986Click image for larger version.
ID:	333988Click image for larger version.
    Latest mods and parts.
    Attachment 335328Attachment 335364Click image for larger version.
    Attachment 335640Attachment 335642Latest updates on this build.
ID:	335632Click image for larger version.
ID:	335634Click image for larger version.
ID:	335636Click image for larger version.
    Latest parts...Attachment 336256Click image for larger version.
    final photosClick image for larger version.
    Feb 2021
    Thanks a lot for this post
  1. splash guards/modifacations
    By Sp-4renegade in forum Tormach Personal CNC Mill
    Last Post: 08-27-2012, 04:27 AM
  2. Aluminum Extrusions, Steel, or Aluminum Tubing which one for CNC frame?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 06-14-2012, 02:51 AM
  3. RFQ: Two Aluminum/Steel Bushings
    By amishx64 in forum RFQ (Request for Quote)
    Last Post: 01-02-2012, 06:42 PM
  4. What's the best saw to cut Steel and Aluminum?
    By morganj2003 in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2010, 08:22 AM
  5. new machine, aluminum or steel ?
    By max_imum2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2006, 02:29 PM
