586,000 active members*
4,764 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Parametric program in Xilog/maestro (lineboring)
Results 1 to 6 of 6
    Sep 2012
    7
    Question Parametric program in Xilog/maestro (lineboring)
    hi there!!
    I am sorry if I am on the wrong place..
    does any one knows how to make a parametric program where the line boring (amount of holes) increases or decreases as the panel size increases or decreases and always have the same distance on both ends?
    I have something similar in WoodWop but I can't figure it out in xilog3 or maestro. This are some of the formulas I use in WoodWob
    amount of holes - NH=MOD((L-9*2)/1.2598)+1
    starting point of line bore - XC1=(L-DL)/2
    distance from first to last hole - DL=(NH-1)*1.2598
    thanks in advance!!
    Jan 2015
    35
    Re: Parametric program in Xilog/maestro (lineboring)
    Don't understand all values you have like MOD( in front , but in xilog3 or Xilogplus you can use L or PAR function
    L NH =(((DX-9*2)/1.2598)+1)/32
    XBO X=50 Y=50 Z=10 R=NH x=32 D=8 N="P"
    Sep 2012
    7
    Quote Originally Posted by dmitry83 View Post
    Thank you for the quick response, I think that value make the number a whole number instead of a number with decimals, for instance (((DX-9*2)/1.2598)+1)/1.2598 is 39.85, in woodwod that value (MOD) will round up the number to 40 (amount of holes in a piece 80" long , DX=80.)
    I try the formula you gave me but it only shows 1 hole
    Jan 2015
    35
    you can test your results with line
    PRINT "Value of NH=?d ; DX=?d" NH DX
    DX is the length of your plate. Like L in woodwop.
    Then if DX=600mm with formula NH =(((DX-9*2)/1.2598)+1) is result 462 holes
    In Xilog for round function is RD round down and RU round up
    L NH =RD(1.9) is 1
    L NH =RU(1.9) is 2
    Service SCM BR Guest
    Hello, dear colleague.
    To perform a parametric program xilog, you could should use either DX or dy- and also the IF function.
    For example DX = DY = 500 600
    XBO X = 50
    XBO X = DX-50
    XBO X = DX / 2
    XBO X = DX (DX / 4 + 50) IF DX <= 500 and DY> 601
    This are just examples but using these codes and functions you get a parametric program Xilog.
    You can also declare variables using the function L
    Example:
    L AA = 50
    XBO X = DX-AA
    Ok?
    Enviado do meu iPhone usando Tapatalk
  1. Replies: 14
    Last Post: 03-27-2022, 07:50 PM
  2. Replies: 1
    Last Post: 09-28-2016, 04:18 AM
  3. Xilog Plus ISO Program help needed
    By igoratoyan in forum G-Code Programing
    Last Post: 10-14-2013, 11:16 AM
  4. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
