585,888 active members*
4,713 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Reduce max speed, increase torque?
    Mar 2014
    1131
    Is it possible that decreasing the max speed of a spindle trough VFD and increase the torque at lower speeds?
    My point is if I can use a 2.2kw chinese spindle as lathe spindle but the max speed I need is 2k RPM so I need to know if VFD drives are capable to play with speed/torque then the idea might be useful. So that there will not be any gearing needed.
    The exact VFD I have is Huanyang 2.2kw.
    Thanks in advance.
    Re: Reduce max speed, increase torque?
    No.
    Mar 2014
    1131
    I thought so. Thanks.
    Aug 2014
    889
    A brushed DC motor is at max torque at 0 rpm.
    All other motors whether inductive or brushless, depend on slip or rotation speed to gain inertia to develop torque.
    Pulleys and belts or gears give you mechanical advantage.
    Its just the way it is.
    Mar 2014
    1131
    I already upgraded my lathe to DC brushed motor with a KB drive for variable speed and it works good.
    But, 2.2kw air cooled spindles are very cheap these days so I thought I better try my luck.
    Thanks.
  1. reduce rotation of spindle speed by parameter
    By sml2010 in forum SIEMENS -> GENERAL
    Last Post: 10-15-2015, 02:25 PM
  2. Does increasing/decreasing stepper steps increase torque?
    By bradtal in forum DIY CNC Router Table Machines
    Last Post: 04-27-2009, 11:18 PM
  3. How to Increase Speed with Mesa and EMC
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 04-01-2008, 07:44 AM
  4. How do I increase spindle speed?
    By cnczoner in forum CNC Machine Related Electronics
    Last Post: 07-11-2007, 02:42 PM
  5. Stepper motor torque increase
    By roni21702 in forum Stepper Motors / Drives
    Last Post: 04-03-2006, 06:39 AM
