Attachment 349802
Holder does stop when and prompts you when you know how to properly set it up.as shown here. so this not an error or a issue.
Attachment 349802
Cadcam
How to set up holder stop and prompt when collide fixture
Mastercam2017 Contour toolpath: Compensation Type
-Computer
-Control
-Wear
-Reverse Wear
-Off
So you bought are Cimco Profesianl Editor with Calc or was that a demo copy of V7?
Cadcam
Mastercam2017 Contour Tool path
Roll Cutter Around Corner
Infinite look ahead
Internal corner rounding radius
External corner rounding radius
Mastercam contour toolpath (continue 3): CONTOUR TYPE
-2D
-3D
-RAMP
-REMACHINING
-OSCILLATE
Mastercam2017 Introduction to Contour Toolpath: 4) Depthcut
-Total Depth & Depth Cut
-Depth Cut Order
-Tapered Wall
-Subprogram
Mastercam2017 Video Tutorial 3D Surface Milling
-Surface Rough Pocket
-Surface Finish Blend
Mastercam2017 Introduction to Contour Toolpath: 5) Lead In/Out
- Entry / Exit
- Use entry point / Use exit point
- Enter on first depth cut only / Exit on last depth cut only
- Plunge after first move / Retract before last move
- Override feedrate
- Adjust start of contour / Adjust end of contour
Mastercam2017 Introduction to Contour Toolpath: 6) Break Through & Multi Passes
-Break through
-Multi Passes
Mastercam 2017 Video Tutorial High Speed Milling
Mastercam 2017 Video Tutorial 3D High Speed Milling
3D Part Model: EMUGECircleSegmentBlade_2017
https://youtu.be/JZFG0U_AKA0
3D step model: FIGURA_S0004
Mastercam 2017 Wireframe Coons Path
3D model Step file: TUBEWINDOW
