Re: OKUMA OSP U100M HELP FOR SMALL MEMORY
hi, there were similar threads lately, about file size issue ; this is all i can do :
Originally Posted by
deadlykitten
on pselect is an option that allows "path" selection, only that it comes with restrictions as the path should be a "device name"
i could acces only MD1 , AD0 , AD1, thus folders on "D drive", but nothing from outside this partition; also i tried US0, but it did not work
also pselect comes with A ( normal file size ) , B ( big file size ) and S ( don't search soubroutines ) atributes, but i don't know if they work for you ..
OkumaWiz
Depending on the control, you may be able to put in in with your system files and run from there. 7000 and u100 use MD0: before that it was BB0: on the 5000 series. They usually had much more memory available in the system files area. You can check it by doing FREE BB0: command. FREE BB0: ;C will show continuous available.
