585,981 active members*
4,059 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Partner 1 Series H - Can 45 degree pull-studs be used?
    Feb 2009
    82
    Now that I have my spindle running, I am now at a point to load up the tool-changer when I came across the documentation that the pull-studs for this spindle requires a CAT40 60 degree angle :-(
    Does anyone know if this machine will work (or hurt the machine) using the regular 45 degree angle on the pull-stud (retention knob)? (60 degree retention knobs will take a couple weeks and I do currently have 45 degree ones)
    The tech at Milltronics wasn't confident enough but was skeptical that you could since a bearing style drawbar was used inside the spindle with these machines.
    Thanks again for all the help!
    Sam.
    Jul 2010
    548
    Re: Milltronics Partner 1 Series H - Can 45 degree pull-studs be used?
    Go here Techniks CAT40 Retention Knob 21003-60 Solid Pull Stud 60 Degrees 10 Pcs
    Just called them, in stock. too late to ship today, but can ship tomorrow. BEST price I have seen.
    sportybob
    Jul 2010
    548
    Guess I was in a hurry to get the "buy" info out there.
    The reason why 60deg is: the size of the balls in the ball lock cylinder dictates a 60 deg angle. 45 deg does not provide enough surface area.
    sportybob
    Jul 2010
    548
    I guess while you are at it, check the drawbar pressure. (draw bar dyno is best) but in a "pinch" put a 20" pry bar between the tool and the spindle nose, you should not be able to move the tool unless you really reaf down on it.
    New drawbar washers will provide ~ 900lbs of pull
    I stock D bar washer kits.
    sportybob
    Feb 2009
    82
    Thanks for the info, just ordering now :-)
    Appreciate it as always!
    Sam.
  1. Haas Pull Studs
    By rrbmachining in forum Haas Mills
    Last Post: 08-12-2013, 01:22 PM
  2. Which CAT 40 pull studs?
    By sortafast in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2013, 05:28 PM
  3. What pull studs
    By zcases in forum Fadal
    Last Post: 11-03-2012, 10:54 PM
  4. Partner I E retention knobs or pull studs
    By Chizel in forum Milltronics
    Last Post: 08-31-2010, 01:11 AM
  5. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
