585,902 active members*
4,016 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Using a lense to selectively alter the cutting beam profile
    Sep 2016
    A friend of mine is experimenting with one of the inexpensive Chinese laser cutters, the beam of which passes through a lense that focuses the beam to a point.
    We'd like to convert the beam of that cutter from a converging beam to a parallel beam at a selectable point.
    Information found on the net indicates that placing a cylindrical lense in the beam path will alter a converging beam to a parallel beam as we'd like but we don't know enough about lenses to know we correctly understand this solution.
    We've found a "25mm focal length cylindrical lense" on eBay -New Edmund Optics Cylindrical Lens 12 5mm Dia 25mm FL BK7 P N 46194 | eBay - but we don't know what a "25mm focal length" is in such an lense, or if the lense we found would suit our purpose.
    Any thoughts would be greatly appreciated.
    TIA
    Oct 2008
    16
    Are you trying to do a light-saber?
    .. the lens you are talking about are something like this.. no? (Attached file)
    Quote Originally Posted by jeb6319 View Post
    TIA
  1. hydraulic swing beam cutting machine for nameplate
    By zihuanew in forum News Announcements
    Last Post: 06-01-2016, 04:32 AM
  2. CNC Beam profile cutting machine
    By Lasersolution in forum Videos
    Last Post: 09-21-2014, 04:20 AM
  3. laser beam split after cleaning tube lense
    By Eimantas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2013, 10:03 AM
  4. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
